Originally Posted by
fred27
It is not the spring alone that affects the ride. Important to remember that the spring needs to be matched to the shock.
This.
A lowering spring needs to have a higher spring rate than OE else the car will bottom out. This in turn works the rebound valving in the DAMPERS much harder than the OE ones are designed for so they will wear out far more quickly than with the OE springs.
Hence
Martin
I used lower springs on stock shocks, the out come was hard and unstatisfactory
Resident grumpy old fart
