Page 8 of 16 FirstFirst ... 678910 ... LastLast
Results 71 to 80 of 158
Thread: RS Eibach lowering springs (family wagon)
  1. #71
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by donweather View Post
    Martin did you get them?
    Yes - I bought my SupaLoy control arms via APR so I got the adjustable ball joints
    Ideally you replace the adjustable bolts/nuts with OEM ones cos they are much stronger
    I had the adjustment maxed out and got 1.45 deg negative camber
    This has improved/increased the car turn in and cornering grip
    I can even brake and turn in without complaint from the car (running dam good tyres however)
  2. #72
    Oct 2009
    Mitchelton, Qld
    Thanks Martin. Greatly appreciated.
    For those that have the Eibach Springs, can I ask where you got them installed (for those that didn't install them themselves) and indicative cost. I've got a quote from one place and it's rather high to say the least.
  3. #73
    Jul 2010
    bout $350 to get mine installed.
    it included a wheel alignment, and another free re-alignment after 1000 kms.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  4. #74
    Erskineville, NSW
    Cost of labour is why I keep recommending you get the dampers done at the same time otherwise you'll be shelling out double in a 6-12month period.
    Have you tried TruTrac?
  5. #75
    Oct 2009
    Mitchelton, Qld
    Trutrac?
  6. #76
    Erskineville, NSW
  7. #77
    Oct 2009
    Mitchelton, Qld
    Google "trutrac" exactly how you wrote it and nothing comes up mate!!!!
  8. #78
    Erskineville, NSW
    That would be incorrect Don, but not to worry.
    Have you just changed your location to Mitchelton because I swear it said Melbourne before. Anyway, TruTrack is no good to you.
    Try Fulcrum Suspension or Accurate Suspension. Both in BNE & recomended by some of my contacts up that way.
  9. #79
    Oct 2009
    Mitchelton, Qld
    Thanks Brad. Have tried Fulcrim. Will give Accurate a call.
  10. #80
    Got some Eibach springs for sale if anyone is interested.
    http://www.vwwatercooled.com.au/foru...tml#post978662
