2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
They are primarily for looks, they will reduce roll somewhat and give a more sporty ride
When pushed hard on less than favourable roads you may hit the bump stops - this is highly undesirable (and can be dangerous)
(Our standard shocks are nothing to write home about - I love the control of my Bilstiens)
These springs won't make any difference to axel tramp
You either need a firmer dog bone mount or the Supaloy control arms
The dog bone mount has terrible/negative consequences (loud and low frequency cabin reverberation) at idle, in stop/start traffice and when reversing - I went back to stock!
The Supaloy control arms are a tad expensive but solve axel tramp, provide better straight line stability and more negative camber which increases corning road holding - given the benefits these are good value for money in my opinion
Resident grumpy old fart
do the whiteline kits do all that too?
I get axle tramp and it pops open the dash hidey-hole which is really distracting. also the actual tramping is bad too
ok checked out their site. they look great! martin, which ones do you have?
http://www.superpro.com.au/superpro-parts/ALOY0001K
http://www.superpro.com.au/superpro-parts/ALOY3273-80K
From all reports, the WALK will have a similar effect to the Supaloy control arms since they both reduce the stiffness (increase compliance) of the front suspension to dive/lift so the suspension doesn't bind up from the geometry in these circumstances.
Martin got the full arm which includes the rear bracket.
BTW: Martin - half an insert is pretty good. I think if they were a lower duro they'd be pretty good all round
yeah ive been reading up about the supaloy product. looks great and value for money. I think ill be getting one in the coming months
ECU upgrade is a worth mod![]()
