Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 158
Thread: RS Eibach lowering springs (family wagon)
  1. #51
    Feb 2010
    Camden NSW
    Quote Originally Posted by donweather View Post
    So for those that have the Eibach lowered springs with stock shocks, can I ask, do these lowered springs assist in anyway with more front wheel traction/less axial tramping etc, or are they purely for handling (cornering)?
    No...Mine still has the worst axle tramp under very heavy take off!
    Just ask Mysticality...he has driven with me.....
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
  2. #52
    Bowral, NSW
    Quote Originally Posted by Tigger View Post
    I wouldn't call it the *worst*... The diesel engine is heavier than the petrol, but it is pretty bad.
    You need to get a whole front end suspension makeover! Pronto!
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  3. #53
    Dec 2012
    Sutherland Shire, Sydney
    They are primarily for looks, they will reduce roll somewhat and give a more sporty ride
    When pushed hard on less than favourable roads you may hit the bump stops - this is highly undesirable (and can be dangerous)
    (Our standard shocks are nothing to write home about - I love the control of my Bilstiens)
    These springs won't make any difference to axel tramp
    You either need a firmer dog bone mount or the Supaloy control arms
    The dog bone mount has terrible/negative consequences (loud and low frequency cabin reverberation) at idle, in stop/start traffice and when reversing - I went back to stock!
    The Supaloy control arms are a tad expensive but solve axel tramp, provide better straight line stability and more negative camber which increases corning road holding - given the benefits these are good value for money in my opinion
  4. #54
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Martin View Post
    Good luck on getting this message through (plus the jouncy, floaty experience on bumpy roads) - I've tried on multiple occassions.
    Resident grumpy old fart
  5. #55
    Jan 2012
    do the whiteline kits do all that too?
    I get axle tramp and it pops open the dash hidey-hole which is really distracting. also the actual tramping is bad too
    ok checked out their site. they look great! martin, which ones do you have?
    http://www.superpro.com.au/superpro-parts/ALOY0001K
    http://www.superpro.com.au/superpro-parts/ALOY3273-80K
  6. #56
    Oct 2010
    Melbourne, VIC
    From all reports, the WALK will have a similar effect to the Supaloy control arms since they both reduce the stiffness (increase compliance) of the front suspension to dive/lift so the suspension doesn't bind up from the geometry in these circumstances.
  7. #57
    Erskineville, NSW
    Martin got the full arm which includes the rear bracket.
    BTW: Martin - half an insert is pretty good. I think if they were a lower duro they'd be pretty good all round
  8. #58
    Jan 2012
    yeah ive been reading up about the supaloy product. looks great and value for money. I think ill be getting one in the coming months
  9. #59
    Oct 2009
    Mitchelton, Qld
    Thanks Martin.
    I am looking at getting the Eibach springs and the supaloy control arms so hopefully that improves the look and feel (axle tramping) of the car, particularly if I also decide to go for an ECU upgrade.
  10. #60
    Jan 2012
    ECU upgrade is a worth mod
