Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 158
Thread: RS Eibach lowering springs (family wagon)
  1. #21
    Looks like $375 plus post
  2. #22
    Mar 2008
    Quote Originally Posted by 240z View Post
    yep, and plus $18 delivery to Melbourne.
    Mk7 Golf GTI PP DSG, Tornado Red
  3. #23
    Jul 2010
    Quote Originally Posted by MrGadget View Post
    I have read that these springs are offered in the UK from the Skoda dealer as an option. Does anyone know if the shocks are also changed or do they keep the stock shocks?
    yup, they were certainly a skoda optional accessory, on stock shocks.
    they r however no longer offered.
    this was the link, which no longer works - http://www.accessories.skoda.co.uk/p...o=ZGB1Z3071677
    and this was the skoda part number: ZGB1Z3071676
    here's mine on the 20mm eibach prokit......
    before..............
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
  4. #24
    Oct 2009
    Mitchelton, Qld
    Could someone kindly provide a link to the correct Eibach 20mm Springs on the Eibach shop webpage as I note they don't provide recommended springs for Skoda vehicles on their shop webpage?
    Are they the same as the Golf GTI ones?
    Pro Kit Buy suspension from Eibach including adjustable suspension and automotive coil springs.
    Also, what difference does the gearbox (manual or DSG) make to the springs? ie, why does the Eibach page have a different link to springs for manual or DSGs?
    Thanks.
  5. #25
    Erskineville, NSW
    Quote Originally Posted by donweather View Post
    Thanks.
    Golf Springs will cause your Skoda to look all droopy in the bum like a 1972 Capri. Skoda is heavier in the back end than a Golf (more overhang & larger glass area), wagon more-so than sedan.
    If you put both kits in the shopping cart the partnos are the same. E108502
    Katalog link
  6. #26
    Jul 2010
    Thanks.
    there are different part number for wagon/estate and hatch/sedan.
    this is from dcperformance. part number will be the same elsewhere.
    wagon version:- E10-79-004-04-22
    liftback version:- E10-79-004-02-22
    liftback/sedan:-
    wagon/combi/estate
    DSGs r heavier than manual gearboxes. hence u'll have additional weight.
    make sure the axle load of the springs r suitable for ur car. it will be on the build plate.
    mine says:-
    1 - 1100kg (Front Axle)
    2 - 1100kg (Rear Axle)
  7. #27
    Oct 2009
    Mitchelton, Qld
    Thanks Guys.
    As I'm not a mechanic, any idea of what I'd have to pay to get these springs installed (and removal of my current ones).
    Also, it says that the springs only lower the car by 20mm, but I have to say that on your car DS, it looks to be more of a 20mm lowering? Do you agree?
  8. #28
    Erskineville, NSW
    1 bolt per side for the rears - about 20mins per side x whatever the hourly rate is.
    Fronts about 45m-1hr per side in a workshop IIRC
    3 hours tops
  9. #29
    Jul 2010
    Also, it says that springs only lower the car by 20mm, but I have to say that on your car DS, it looks to be more of a 20mm lowering? Do you agree?
    Ur half right.
    I measured (top of wheel arch to floor) it, before & after - my fronts dropped 30mm, while the rear dropped the expected 20mm.
    Don't know why. DSG? Equipment level?
    As a result, it required my xenon levelling to be recalibrated.
  10. #30
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by fred27 View Post
    It is not the spring alone that affects the ride. Important to remember that the spring needs to be matched to the shock.
    This.
    A lowering spring needs to have a higher spring rate than OE else the car will bottom out. This in turn works the rebound valving in the DAMPERS much harder than the OE ones are designed for so they will wear out far more quickly than with the OE springs.
    Hence
    Quote Originally Posted by Martin View Post
    I used lower springs on stock shocks, the out come was hard and unstatisfactory
    Resident grumpy old fart
