Page 1 of 16 12311 ... LastLast
Results 1 to 10 of 158
Thread: RS Eibach lowering springs (family wagon)
    Mar 2008
    Hi guys, first of all I love my RS wagon but can't help thinking about how much better it will look with a lowered stance. Since this wagon will be used with a newborn due in August I was hoping others had some experience in my situation as I obviously don't want the ride to be rough and unpleasant for a baby. So should i forget about lowering it or do the Eibach springs provide a good ride.
    Thanks.
    Mk7 Golf GTI PP DSG, Tornado Red
    Erskineville, NSW
    I have RS Diesel Wagon springs on my TSI Sedan. They work quite well except the front dampers weren't really up to the job so 15,000km after installing the springs i had to replace all the dampers with Koni Sport.
    The rear spring rate is perfect with the dampers set to 3/4 turn from soft.
    The front needs 1 turn from soft or it nods it head a bit too much on high frequency bumps.
    Initial compliance is very good with konis, not so good with OEM.
    Re: Babies in modded cars - they don't care & if they do they don't say much. It's their mother you have to worry about.
    Dec 2012
    Sutherland Shire, Sydney
    Ain't that the truth!!!
    Tigger has the Eibach lower springs
    I used lower springs on stock shocks, the out come was hard and unstatisfactory
    I switched to Eibach springs and Bilstein shocks - wonderful solution (back to factory ride height)
    Jul 2010
    I've got the eibachs (20 mm) on mine.
    Been more than a yr now (I think....) and its all good. Ride is still comfortable, for 18 low profiles, and it looks much better than stock.
    My little girl was 2 yrs old then - no complaints.
    My wifey - no complaints. Infact, she didn't even notice the difference in ride!!
    .....or the slightly lowered stance!!
    And she drives the car 90% of the time!
    Which is good - "subtle" right
    Apr 2013
    Fitted Eibach 30mm lowered springs (Factory option in EU) to my Fabia RS wagon a few weeks ago. Comfort is no different. Handling and look greatly improved. Ideally you would replace the shocks if performance is your main goal, but everyday driving the springs are fine on their own.
    Nov 2010
    NSW
    darkshadow & mmmracer - that sounds great.
    i've been contemplating eibachs lately and your positive experience is helping me make the decision. although i've got a 90tsi so I imagine the chassis will sit lower (or look lower anyway) because i've got puny wheels.
    2012 Yeti 77TSI, Candy White
    ydad.com.au: musings of a dad growing up - the blog.
    cbay.com.au: photography, video, design - creations.
    May 2012
    Lyndhurst Victoria
    Quote Originally Posted by cbay View Post
    Cbay, I think you will find that you will get the full quoted 35mm drop on s 90tsi because your chassis sits 15mm higher than the VRS. I'm considering these springs too but after plenty of research I am quite tempted by H&R springs with the same drop. I have decided against dropping mine any lower than that.
    *****CURRENTLY FOR SALE***** See Sale thread
    Candy White MY12.5 Octavia VRS TSI DSG wagon.
    Black Plasti Dipped wheels, grille surround, roof rails and badges. Lowered 20mm, torque arm insert.
    Mar 2008
    Seems like a bit of mixed comments here. Where would one purchase these springs from? Getting them fitted isn't an issue as a family member is a mechanic.
    Erskineville, NSW
    I got my Eibachs off the forum (Brand new in box) & Konis from ECS tuning.
    If you were considering height adjustable coilovers then Golf units fit (these pop up on the forums regularly too). Keep in mind that the smaller engined Golfs/Octavias have a 50mm strut & the larger a 55mm.
    There was a good thread posted the other day about suspension mods / different springs & shocks for Octavia. Can't find it now.
    Apr 2013
    Got my springs direct from Eibach Australia. Very easy to deal with.
