Threaded View
MrGadget RS Eibach lowering springs... 24-06-2013,
01:03 PM
brad I have RS Diesel Wagon... 24-06-2013,
02:58 PM
dArK5HaD0w I've got the eibachs (20 mm)... 24-06-2013,
06:18 PM
Martin The ride height certainly... 26-06-2013,
08:53 AM
dArK5HaD0w Ur half right.
I measured... 27-06-2013,
08:41 PM
dArK5HaD0w +1
I'm having no issues at... 28-06-2013,
06:03 PM
dArK5HaD0w I can't wait to get my... 20-07-2013,
09:55 AM
dArK5HaD0w I've got mine set to medium.... 24-08-2013,
02:14 PM
dArK5HaD0w correct part num for zee... 06-05-2014,
01:00 PM
donweather Just a question. What's the... 14-06-2015,
07:13 PM
donweather I note that the Eibachs... 15-06-2015,
12:51 PM
donweather Unfortunately no part #'s... 15-06-2015,
01:45 PM
donweather UK sites all state... 15-06-2015,
03:44 PM
donweather Well got confirmation from... 16-06-2015,
08:49 AM
brad Confusing isn't it...
... 16-06-2015,
08:55 AM
donweather Well just got the following... 16-06-2015,
10:19 AM
GeeMatt Fair point ! :emo_baghead: 20-06-2015,
07:53 PM
donweather Does any one know the load... 22-09-2015,
08:24 PM
brad try BC-Racing or Tein
... 23-09-2015,
09:25 AM
99Reza MCA Suspension located in... 23-09-2015,
10:20 AM
brad That's who I mean. 23-09-2015,
10:32 AM
dArK5HaD0w on eibachs, my RS dropped... 24-09-2015,
01:20 PM
donweather dS are you still on your... 24-09-2015,
08:07 PM
donweather Sweet thanks DS. 25-09-2015,
08:51 PM
donweather Got the new Eibachs installed... 21-11-2015,
08:23 PM
donweather DS, I just checked your build... 23-11-2015,
10:46 AM
donweather I measured from ground... 23-11-2015,
11:38 AM
dArK5HaD0w as per my build timeline -... 23-11-2015,
12:39 PM
donweather There's no way with those... 23-11-2015,
12:51 PM
dArK5HaD0w apologies don, i went back... 23-11-2015,
01:57 PM
donweather Cheers DS. I hope I get more... 23-11-2015,
03:28 PM
dArK5HaD0w i just took another... 23-11-2015,
06:53 PM
Mysticality You can always get something... 16-02-2017,
03:04 PM
There's no way with those measurements in the 670mm range that you measured to the centre of the hub DS. You've measured from the ground surface for sure.
I have a manual. Surely the DSG can't add that much weight (20kgs?) to the front to drop the springs a further 13mm? I have the wagon springs (wagon = 10-79-004-04-22)...just checked the Eibach specs. They are different from Sedan to Wagon:
Sedan
Fronts: 11-79-004-01VA (1050kg)
Rears: 11-85-014-05-HA (1100kg)
Wagon
Fronts: 11-79-004-02VA (1100kg)
Rears: 11-15-007-01-HA (1150kg)
So there you have it....different springs with the unloaded wagon weight combined with manual probably explain the differences in drop heights now (also noting mine still probably have another 5mm to drop as they settle in). Actually, there's differences in the untensioned spring heights (10mm) between sedan and wagon for the rears too. See pics below from Eibach Specs:
I'll remeasure in a few weeks time to see how much they've settled in (if any).
And there is a slight difference in the overall wheel arch spacing....it's just that you can't tell much from those pics of mine above due to differing shadows on the tyres in the pics.
I'm still baboozled by the difference in heights between my stock OEM and your stock OEM though DS....particularly at the front (that's 20mm on OEM). You're running 225/40/R18's yeah? Must be different OEM springs also between wagon and sedan....althoguh seems odd that my wagon was lower OEM if you use the same logic above (spring weights etc) for OEM springs?
I did get new top mounts installed in the fronts at the same time. Perhaps my OEM top mounts were stuffed, hence the new mounts have pushed it back up somewhat? But only done 55,000 k's.....hard to imagine OEM top mounts that rooted?
- You may not post replies
- You may not edit your posts
Forum Rules
