Page 13 of 16 FirstFirst ... 31112131415 ... LastLast
Results 121 to 130 of 158
Thread: RS Eibach lowering springs (family wagon)
  1. #121
    Oct 2009
    Mitchelton, Qld
    Well just got the following response from Eibach "The Eibach Pro Kit is not intended for towing purposes."
    So there goes my efforts to use Eibach springs to lower my vRS.
  2. #122
    Erskineville, NSW
    Quote Originally Posted by donweather View Post
    What does that mean? That makes no sense. Plenty of folk at Briskoda have Eibachs & tow small vans, etc
  3. #123
    Oct 2009
    Mitchelton, Qld
    Yeah surprised me, also considering Skoda released the Eibach's as a factory option in Europe/UK. But just to complete the picture as to Eibach's response above, here's the question I asked them.
    "I regularly tow a Jetski with a fully loaded wagon, so will these springs handle this additional load travelling at speed (100km/hr) on the highway on the stock vRS dampers/shocks?"
  4. #124
    Glen Waverley, VIC
    Where are you up to Don. Did you go ahead ?
    Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
    Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
    Weekender/Project:
    Classic Mini 1972
    Dependant #2: Mk4 2001 GTi
  5. #125
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by GeeMatt View Post
    I don't really think I can proceed now can I? Where would I stand with my insurer if I installed them and then had an accident whilst towing.
  6. #126
    Glen Waverley, VIC
    Fair point !
    Weekender/Project:
    Classic Mini 1972
  7. #127
    Oct 2009
    Mitchelton, Qld
    Does any one know the load rating of the stock OEM vRS wagon springs including force displacement characteristics? Or point me in the direction of where I could find this info please.
  8. #128
    Erskineville, NSW
    The last time I needed info like that (for a Subaru) I had to pull springs & get the spring maker (K-Mac) to test them for me. Pedders would be able to do the same thing.
    Put the call out and see if any other forum members up your way have a set of vRS wagon springs you can borrow to get tested.
    You should also be able to work out the spring rate by measuring the wire length and the wire diameter.
    Why so set on Eibachs? Get some locally made coilovers
  9. #129
    Oct 2009
    Mitchelton, Qld
    Suggestions?
    I'm not after a big drop. The 20mm quoted by the Eibachs would be ideal for me and I can get them cheaper than a good set of coilovers. I've just heard good and bad about coilovers, particularly the cheaper ones, hence don't know which coilovers to really go for and don't want to spend alot of coin for 20mm drop. Also note I tow a jetski hence the limited drop and don't know if coilovers are up to the task (safe at high speed) of towing.
  10. #130
    Erskineville, NSW
    try BC-Racing or Tein
    There was another mob I found the other day - can't remember the name though. Micheal somebody - he used to do a lot of rally stuff -esp Subarus.
    Have you looked at H&R or KYB springs?
