Nice find / mod Mate!
Decided to start a thread on this as the previous mentions in other places were getting messy....
Discovered on another forum an easy mod to free up the breathing on our cars.
Most tuners I spoke with agreed that the standard air box with a decent panel filter would easily flow enough air for a stage 2 tune.
The standard cold air intake on the car draws most of its air from the engine bay & has a further cold side which is blocked from factory
I removed the intake and cut out the bits as required
There is already a factory air feed from behind the bumper in place by both cut outs
I blocked off the hot air feed from the engine bay with some aluminum tape & also the resonator box inside the air box
I also removed the silly snow screen at the bottom - not really required here in Australia
Haven't had much of a chance to drive it tonight & still yet to buy a replacement hi-flow filter but the diverter valve can now be heard with the windows down.![]()
MY16 Octavia VRS Wagon, DSG, Race blue, Tech pack, Comfort pack, Black Pack, 19's, Sunroof, Electric Tailgate
Airbox mod, VW Racing Filter, TMD, Elbow, Ramair Pipe, GFB DV+, VCDS mods, Superpro adjustable rear sway bar, Superpro end links, Whiteline front sway bar links, Whiteline LCA bush Kit, Bilstein B14 coilovers, HPA dog bone mount & arm, 42DD oil catch can, Burger wheel spacers, CTS downpipe 200 cel cat, 2,5" exhaust , twin out. Super Skoda eyelids & front splitter, Tuned by BPS 228kw atw, Dsg tune,
I rang Hardings Performance today as they sell an R Line performance panel air filter, but they are out of stock until the end of January.
Byron whom I spoke to again tried to sell me the full intake which is around $1200 and reckons ill gain 30kw!! - I personally call BS as they are a forced induction engine and need an extra 4-5 psi positive boost to achieve that same figure with a tune.
VW probably spend a lot of R&D money getting the air box right, a Golf R will quite happy produce 206kw with the same unmodified box & paper filter....
Give me $1200 and I ll tell you you've gained 500 KWs.
2014 MY14 Corrida Red Elegance Wagon TDI
2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
2011 MY12 Yeti 77 TSI DSG.
[QUOTE=Antiplastix;1211273]Give me $1200 and I ll tell you you've gained 500 KWs.[/
Deal, but only if it comes with a sticker, so all the other drivers know what I'm packing under the hood
Does anybody know where I can purchase a replacement panel filter either locally or overseas?
Was keen for the Racing Line Filter but it appears the only Aus distributor is Hardings (out of stock till early Feb) & the overseas website keeps redirecting me there
I'm not keen on an oiled filter such as K&N or BMC, prefer to use the foam
