Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Reversing LED (CREE)
  1. #21
    Apr 2012
    This is the T20 reversing LED CREE bulb for Golf 118's... I found out today it is different to the T15 reversing bulb used in the R tails (glass bulb on the left).
    And it looks like this when working...
    MY11 Golf .:R | 3 Door l Rising Blue l 3 Pedals l 19" Silver Talladega l Leather l Nav | Bluetooth
    To see my Build Thread >>>Click Here<<< Watch my Videos >>>Click Here<<<
  2. #22
    Dec 2012
    Sutherland Shire, Sydney
    GregoInc - our Octavia's use a P21 bulb rather than those litte T15/T20 fellas
    I have yellow LEDs for all my indicators. No errors. They are generic Chinese ones from aliexpress so I can't find a link at this point.
    I've done that tonight also - the car does not appear to test/check the indicator bulbs
    While my LED blinkers are much brighter than the bulbs, they turn off/on instantly
    The bulbs glow on/off giving more light duration
    But the thing is, the LED's are more visible in the day time
    I tried LEDs for reverse and stop lamps but they were not bright enough.
    Our P21 LED's (see previous photos) have multiple CREE's which are at least twice as bright as the original bulbs
  3. #23
    Dec 2012
    Quote Originally Posted by Martin View Post
    These are not working error free - boo hoo
    They don't generate errors when you turn the car on (the previous set generated errors immediately)
    However they do generate errors when you use them, so when I engage reverse a light bulb failure appears on my dash and in the MFD
    So after a few days, the warning about the right reversing light no longer appears
    So I removed the left one, cleaned it, fiddled with the fitting, put it all back together, and now that one does not create a bulb failure warning either
    I can't understand what has changed but I'm happy - and won't touch it again!
  4. #24
    Bowral, NSW
    How much, where from and wheres the link!!!
  5. #25
    Dec 2012
  6. #26
    Jan 2013
    Is there any way we can combine all this LED info as I've spent the morning looking for the thread regarding the DRL's (I know I've read it here somewhere). There is buckets of good advise and experience here just the search function is struggling with "LED"
