Originally Posted by
Diesel_vert
A tyre with a higher profile with a taller footprint, which doesn't lose contact with the road as much compared to less compliant low-profile tyres and newer or fresher rubber may explain his observations.
Taller profile on the tyre (more rubber on the side) = larger flat spot on the ground.
Go check out how 4WD tyres work offroad, for an exaggerated example.
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
