![Quote](https://www.vwwatercooled.com.au/forums/images/misc/quote_icon.png)
Originally Posted by
brad
Personally, i think you'll be pretty disapointed in the result though.
Because of the taller tyre profile (since the vRS is the equivalent of a GTi)?
225/55R16 is almost spot on for rolling diameter, has the same contact patch and would be only marginally less responsive.
If the improved ride means DunlopRS doesn't have to slow down for rough patches or run really high tyre pressures and have the car crashing about, then that's a real world performance gain.
K1W1
Running 45 psi is a recipe for disaster. ..... That sort of pressure on any road surface with irregularities is simply asking for a monumentally large blow out and instant tyre deflation to occur when you roll over something that is sharp and pointing at the tyre.
Tyres are far tougher than that - damage from sidewall pinching over sharp edges is far more likely than any possibility of puncturing due to lack of pliability
Resident grumpy old fart
