Results 1 to 10 of 19
Thread: Rear Tyres Feathering
    Feb 2014
    Geelong, Victoria
    Just had the VRS in for first service (12500 k), and requested the tyres to be rotated. The dealer said they did not rotate the wheels as the rears had feathering and would be noisy if place on the front.
    I have searched through the forum and it seems to be a problem with the Octavia regarding tyre wear.
    So my question is:
    1. just how noisy would they be, if I rotated them; and
    2. Can anyone recommend a good alignment place in Geelong or Ballarat (I will even go to Melbourne for the day if someone can highly recommend a place).
    Are Continental Sports Contact 2 prone to this type of wear. The Yokohama on the wife's Lancer have done 85000 k with 1.5mm left to the wear mark, and the son just replaced the Kumho on his Mazda 3 Sports @ 68000 k.
    Moreover, I realise that tyre wear has many variables due to wheel alignment, tyre pressure, pushed hard into corners etc but, to have this type of wear @ 12000 k on a car that has been driven at a leisurely pace seems a bit rich.
    TIA for any help and recommendations,
    MY13 VRS Octavia Wagon, 2.0 TSI, DSG. Platin Grey
    Nov 2009
    Illawarra NSW
    The tyres aren t going to be any noisier on the front than they are on the rear, so that's just a cop out. On my Mk. II vRS I had the rear camber set to standard (non vRS) specs and doubled the tyre life of the second set of tyres.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
    Who is messing with my profile?
    Good soft tyres like the OEMs are good for at least double that when driven respectfully. So have that alignment done. It reminds me I need to do mine straight after I take delivery.
    I've heard Tru-Track in Melbourne is reputable.
    Jun 2011
    Sydney NSW
    I had similar problems with Dunlop SP Sport tyres on my Caddy. It looks like your tyres are also asymmetric tread tyres as well.
    Different rolling resistance across the tread face will see the tyre "twist" and this causes this abnormal wear.
    It is not unique to a particular car. I have seen the same issues on a BMW with asymmetric tyres.
    You need to keep the tyre pressures up, but the only cure is to replace them, and then look at getting a symmetric tyre. Mine showed abnormal wear at the 5,000 km.
    Feb 2014
    Geelong, Victoria
    Thanks for the above comments. Found a VW specialist in the Geelong area with a Hunter alignment rig, so I will see what the options are to rectify the problem.
    Erskineville, NSW
    Quote Originally Posted by Fourwinds View Post
    So my question is:
    That's pretty crap tyre wear. I'd expect at least 25,000km out of CSC2s - and more likely 40,000km.
    1) They'll hum a bit but X-rotate them so they are rotating in the opposite direction & the high spots should wear off after a few thousand km. Run them about 36psi (or more) all round as well.
    2) Ralf at Tru tRac in MEL is pretty good. I don't know the other places (regional centres) but surely there are some options.
    You'll probably find the rears are at about 1.5 degrees -ve camber. You need to bring it to about 3/4 degrees negative. Toe should be about 2mm in IIRC.
    Fronts should be around 0.8 -ve camber & if the wear is OK then it can stay there. You can force a small amount of adjustment out of the ball joint bolts but it's minimal. If the camber difference is too far on the right you can move the x-member.
    I had CSC2 on my Octavia Elegance as OEM. The dealership must have done a great alignment as part of the PD (it should be checked) and I never had any feathering / saw-toothing.
    Erskineville, NSW
    Quote Originally Posted by wai View Post
    Sorry, I really can't agree with your twisting theory. It's an alignment & pressure issue.
    If by "symetrical" you mean directional tyres then again, I don't agree. If you mean a traditional non-assymetric / non-directional then good luck finding a 225/40r18 as fitted to the vRS.
    Dunlop SP Sport are a fairly rubbish tyre (as are most Dunlop tyres IMO). I'm not surprised you had wear issues.
    Jun 2011
    Sydney NSW
    No, not directional, this is where there is a difference in tread pattern inside to outside.
    Jul 2010
    my CSC2 (factory fitted) lasted 62,000 kms.....and there was close to 2 mm still left.
    had no issues whatsoever - wearing, or gripping related.
    i'm CSC5 now.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Feb 2014
    Geelong, Victoria
    Just had the alignment checked, the alignment guy said the stealer ship was talking crap..... The tyres were find and no feathering was apparent but the alignment was out.
    Attached Print-out
    Attached Thumbnails Attached Thumbnails Rear Tyres Feathering-wheel-alginment-jpg
