Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: R.I.P. - My engine (2009-2013)
    Jul 2009
    Coffs Harbour
    This is not a happy day...
    As I type this, my RS wagon (which is still for sale ) is getting an autopsy done on the engine.
    The other day I tried to start the engine and it just turned over without firing. I knew I was low on petrol, but I thought there was enough to get me to the servo. So, assuming it was completely empty, i put about 10 litres in from a jerry can.
    Still nothing..
    I called the NRMA who put another 10 litres in
    Still nothing, the engine turned, but would not start. The mechanic assumed it was a fuel pump failure and we got it towed to the local Skoda dealership.
    I called later in the day and the the engine has no compression, on any cylinders, and the probable cause is the timing chain tensioner failing and the chain shipping a few teeth on start up. If this is true then a new engine will be needed.
    My factory warranty expired in August '12, but it has always been serviced at Skoda dealerships. So who knows how much this is going to cost.
    I'll keep you posted, but for now the RS is off the market...
    I'm sorry for your loss
    He was a well respected engine around these parts.
    Dec 2008
    Sydney/Canberra
    Try for a goodwill repair.
    Seems to be becoming a common failure.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2012
    that is NOT good. ive heard a few people in the UK have had this happen, but this is the first here that ive read about.
    I hope skoda do the right thing by you!
    With the warranty expiring that close, I would expect Skoda to come to the party. That is not an acceptable lifespan and if they insist on selling and marketing Skodas here at premium, then they can cop the other side of that with the statutory laws holding them accountable.
    Which engine is this, the FL TSI?
    Timing belts/chains always make me nervous, especially when I bought my car, I was told it was due at the 4 yr mark regardless of kms, and then when I got there, it was suddenly 7 yrs and 105k. Big change and I was wondering who benefits if it goes wrong before that.
    Just digging up the issue I mentioned a while back, it was the engines after the BWAs, ie unless I'm wrong this engine that has had heaps of issues with pistons and rings. A revised engine was coming in, ie probably what is in the Mk3. Rebuilds aplenty for the engine after the BWA apparently.
    Dec 2012
    Sutherland Shire, Sydney
    Quote Originally Posted by Gaz View Post
    It's not that bad - if the valves have not hit the piston you may just need a new tensioner and rebuild
    If they did hit the pistons it's still only a top end rebuild (assuming the pistons are ok)
    Labour is where the money will go - not on parts or a new engine
    I know it's a major bummer but chin up mate
    Feb 2010
    Camden NSW
    So sorry to hear!!!
    How many Km's had it done?
    Warranty period is one thing, but if it is under the Kms by a fair bit they should take that into account
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Apr 2012
    Perth
    If Skoda don't come to the party, you should be able to go to consumer protection - under new laws, the warranty period is not the only thing taken into consideration.
    You should expect a $30k+ vehicle to last longer than 4 years.
    Jul 2009
    Coffs Harbour
    Thanks for the support guys.
    Woofy - yes, it is the FL TSI engine. What is BWA?
    Tigger - 80,000 Km's.
    The workshop was still doing a report for Skoda, detailing the damage, which was described to me as "Catastrophic".
    The car was originally ordered through Steve Jarvin in Sydney, who are no long dealing in Skoda.
    Skoda have been notified, but are waiting for the workshop report/evidence before making any offer.
    The only positive so far is that I didn't sell the car to someone only to have it self destruct for them. That would be nightmare.
    I'll post again when Skoda have responded.
