This is not a happy day...
As I type this, my RS wagon (which is still for sale
![Face Palm](https://www.vwwatercooled.com.au/forums/images/smilies/facepalm.gif)
) is getting an autopsy done on the engine.
The other day I tried to start the engine and it just turned over without firing. I knew I was low on petrol, but I thought there was enough to get me to the servo. So, assuming it was completely empty, i put about 10 litres in from a jerry can.
Still nothing..
I called the NRMA who put another 10 litres in
Still nothing, the engine turned, but would not start. The mechanic assumed it was a fuel pump failure and we got it towed to the local Skoda dealership.
I called later in the day and the the engine has no compression, on any cylinders, and the probable cause is the timing chain tensioner failing and the chain shipping a few teeth on start up. If this is true then a new engine will be needed.
My factory warranty expired in August '12, but it has always been serviced at Skoda dealerships. So who knows how much this is going to cost.
I'll keep you posted, but for now the RS is off the market...
