Results 1 to 5 of 5
Thread: Pulling apart AC fan to remove debris - help!
    Nov 2012
    Melbourne, VIC
    Hi. I've spent the morning trying to get access to the blower motor using the instructions from Briskoda:
    irritating squeal from air con - Skoda Octavia II (2004 - 2013) - BRISKODA.net
    Unfortunately I'm stumped at step 3 - I just can't get this to happen:
    "Lift clip (near the connector) and rotate bottom of blower housing. Blower motor and fan come out downwards."
    I just can't locate a clip that seems useful What does it look like? There is a metal bracket, maybe 6-8 mm wide, that clips under the unit, but I only managed to bend that trying to lever it off. The view I have from underneath doesn't look exactly like the picture in the Briskoda thread.
    MY10 Octavia Wagon in Candy White, 118TSI, DSG7
    Jul 2014
    I did my previous Octavia 2 to remove a car park ticket, but mine was the same as the image.
    I presume you have managed to remove the electrical connections easily?
    The little plastic tab with the arrow near the wire is located in a 'gully' and just has to be eased over the locating ridges.
    Turning the whole motor then allows it to be released and the off-centre location of the motor is then given clearance to pull out.
    The tricky bit is not getting a face full of dirt as the motor and mounting comes out.
    Of course yours may be slightly different as I don't remember any metal brackets.
    Google and youtube is your friend in these circumstances.
    You might want to post a picture of your situation, that would help.
    Nov 2012
    Melbourne, VIC
    Looks a little different! I think the orientation of my photo is similar to that at http://img855.imageshack.us/img855/8983/belowblower.jpg but the features aren't all the same.
    Pulling apart AC fan to remove debris - help!-cam00687s-jpg
    Where abouts on this pic is the clip in question?
    In this pic, I have only removed one of the switches, there is another one still attached that is easy enough to remove.
    Nov 2012
    Melbourne, VIC
    OK got it!
    All suddenly made sense when I was lying underneath it at the right angle, then the only trick was rotating the unit in the correct direction to remove it. 1 shredded parking ticket removed, noise gone.
    Pulling apart AC fan to remove debris - help!-ticket-jpg
    Erskineville, NSW
    Quote Originally Posted by roshea View Post
    At the 10'oclock mark the tab there will have a screw - remomove the screw
    Follow the loom and at 2'oclock there's a plastic tab with an arrow right next to the loom. pull this downwards so it clears the locating lugs & twist the fan motor.
    I think that should work
    Pulling apart AC fan to remove debris - help!-belowblower-jpg
    EDIT: SORRY, didn't see your photo. The tab is still at the 2'oclock with the arrow on it. There should also be a locating screw somewre but your photo's a bit crap.
