Took the Octavia to Spinning Wheel for a 4-wheel alignment yesterday because:
a) I fitted some Eibach springs a couple of weeks back which lowered the front 30mm & the rear 10mm (so I figured the front will be toeing in a bit)
b) The car has never had a wheel alignment in 103500km. Tyre wear patterns have always been acceptable so i figured why fix what isn't broken.
My thoughts:
- They have a really nice wheel alignment machine. I wish I had one.
- The alignment guy does lots of VWs & is fully aware of how the tyres wear on these vehicles & what adjustment options there are.
- I've been out of the trade too long (not sure if this is a good or bad thing)
The tech worked out what was wrong with the alignment before he'd even started the machine up ("You've probably got too much -ve camber on the rear & too much toe-out on the front"). I was surprised as my tyres have always worn evenly but he was right as my fronts do have a bit of inside wear if you have a really close look.
He was pretty right - I didn't write down the figures but the rear had -2 degrees camber each side - can't remember the toe reading & the thrust line was off to the left which explains the slight drift to the left that I had (I put it down to road camber). So he made the wheels a bit more vertical & sorted out the toe & thrust line.
Cambers were 0.9L & 0.75R which I was happy with. Toe out was around 2.5mm. IIRC he set it on zero.
Price was quoted as "From $119 for a 4-wheel alignment but it will cost more if there are lots of adjustments" & the final bill was $119, so I assume extra cost is for moving the front chassis, etc. It took him about 30mins to do the job.
Car feels much the same as before. Steers straight with a slight drift down the camber of the road - before & after I could take my hands off the steering wheel when trundling along the M5.
I still can't fathom why I get such good (even) tyre wear - the original CSC2 got over 40,000km & hit the wear bars evenly; the 2nd hand Khumos wore evenly from 4mm down to 2mm in 10,000km without edge wear & the Michelin Primacy I fitted at 55,000km are down to 4mm at 103,500km & would pass muster to 95% of people that looked at them.
Anyway, I'm a happy chappy at this point & would recomend them.
