Power window operation from key buttons
Hi All,
Love my new RS. I'm sure we're going to be very happy together. I'm still going through the manuals and getting used to things. My wife bought a Golf VI Comfortline TDI last year, and while there are a lot of familiar bits and similarities there are also some things quite different.
One thing someone might be able to advise on is the operation of the power windows via the key buttons. On the Golf you hold the lock/unlock buttons down and all of the windows close/open. On the Skoda I can only lower the driver's door window via the key unlock button.
The manual says it should operate the same as the Golf, but I can't get it to do so. The book also says that I can close the sunroof via the locking button on the key.
So in summary here's what's going on,
- I can open only the driver's door window by holding the unlock button down
- I can close all windows and the sunroof when I hold the lock button down.
And yes, the window deactivation button on the drivers door is positioned to enable all windows to be operated at the doors.
It's not much of an issue with winter coming on, but I'd like to get it sorted out none the less. On a hot summer day it's great to crank all the windows down before getting into the car. The reduction in internal temperature is huge and immediate.
Any help appreciated, as always.
- You may not post replies
- You may not edit your posts
Forum Rules
