Originally Posted by
mazstar1980
I think you're right, going by manual on the Skoda app. Dealers are using Castrol 504/507 almost exclusively.
I still wouldn't use additives tho.
He is right. About the only amendment is that 505 is for diesels without dpf.
Yes, dealers pretty much all use 504/507 these days as it means the techs don't have to think before putting in the oil.
I'm pretty sure the Skoda owners manual also uses words similar to "Skoda does not recommend the use of additives"
I've run additives in the past. Without conducting used oil analysis & component wear testing you wouldn't know if they helped or not.
I think the best thing you can do for your engine is change the oil & filter more often - maybe every 7500-10,000km rather than 15,000km.
