Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Poor demisting? Any experience
  1. #21
    Jan 2012
    Earlwood, NSW
    Quote Originally Posted by wai View Post
    So, the A/C is an excellent way to demist the windscreen, ...
    Maybe my wording didn't come across right. I agree, which is what I meant when I said "A/C cold", and said earlier, " A/C cold air is often the quickest way to demist in damp, i.e. humid conditions. The cold and very dry air passes over the condensed moisture on the screen and pulls the moisture away leaving it dry and clear."
    I didn't think it necessary to explain why A/C air is dry. I thought most here might know that whether outside a house or a car when the A/C is on the external drain tube will be emitting condensate that was present as moisture in the air inside the house or car.
    The MAX option for demisting does exactly this. It uses high fan speed and refrigerated air well before the engine temperature has had a chance to get up to have any effect and turns on the A/C.
    Yep, "Climatronic also includes a defrost function which can be activated at the push of a button to clear fogged or iced-up windscreens. This directs the full airflow onto the inside of the glass at the highest blower and heat output settings. If the outside temperature is above 0 °C, the cooling system cuts in too to dry the air before it is heated."
    Note that MAX only kicks in the Climatronic air above 0C. dagget mentions -3C, which doesn't surprise being on top of the GDR. It's not only cold up there, but the humidity doesn't drop below 90-95% through June and July.
  2. #22
    Sep 2009
    Quote Originally Posted by dagget View Post
    Problem is we are cold/damp as we are high up 700m and more likely to get rain given our location the the ranges.
    We have about 300mm more rain per year on average than you get at Trentham.
    Has anybody ever wondered why on a sunny day in Winter many used car yards have all the cars open with the boots and bonnets up and the windows down? Well now you know....
    My Škoda photos here
    Flickr : Blog
  3. #23
    Sep 2009
    Quote Originally Posted by BottomScratcher View Post
    All European cars since the 1980s have had the optimum settings for demisting clearly marked on the heater controls. These days it's often a push button in the old days it was a correct setting for the levers and knobs. To demist a European car you don't even have to open the owners manual you simply have to open your eyes when you are sitting in either of the front seats.
    Flickr : Blog
  4. #24
    Jun 2011
    Sydney NSW
    Oops. Did not mean to have a go.
    By the way, I recall a friend of mine had a Mitsubishi Magna, and it had a reverse cycle A/C so that you had warm air to warm you and demist immediately the engine started.
  5. #25
    Jun 2011
    Sydney NSW
    Quote Originally Posted by K1W1 View Post
    When I last had my Caddy serviced (July last year), someone at the dealership (in Penrith) did not close the rear barn doors properly on the loan car so that when I picked it up, there was so much water on the inside of all the glass that it took all day to dry out.
  6. #26
    Jan 2012
    Earlwood, NSW
    Horses for courses I suppose. Having spent most of my life working with explosives I'm more of a "Read the manual" type than a - as it gets turned on - "What's this switch do?" type. And an "optimum setting" is greatly dependant on the climatic conditions at the time, e.g. the Climatronic not operating below 0C.
    We're a bit slow in Oz. It's not that long ago that we caught on to double glazing our houses. It was never done here because of the attitude that this isn't Europe, so we didn't need it.
    The same logic applies to trucks. In Europe trucks have night heaters. An external burner uses a tiny amont of fuel drawn from the main fuel tank to supply warm air to the cab for sleep/rest comfort. They can also be set on a timer, so if left unattended in a yard the heater will come on an hour or so before the driver turns up, so ridding the hassle of deicing windows, and or getting a foot or more of snow off the cabin roof. Seemingly Australian truckies mostly prefer to freeze their rear ends off.
    The same with cars. European cars have night heaters as an option. Skoda call it Auxiliary Heating. It's in the book . While working OS. I've had a BMW, and a Range Rover with night heaters, and they're nothing short of brilliant.
    I've no doubt that if I lived in Canberra, or anywhere on top of any of the ranges or highlands where the temps go subzero and are mostly below average, and where the winter humidity is mostly higher than average that I'd have ordered one as an option ex-factory when buying my Octy.
  7. #27
    Jan 2012
    Earlwood, NSW
    No worries. Written words don't always get taken in the context they are written. Especially the way I can butcher English.
    I've heard of a 4-way reversing valve that can be used to convert standard auto a/c to reverse cycle, but didn't know about the Magna.
    I've seen it mentioned for caravans, but for cars I'd think demisting at cold start is the only time it would be useful. Once the engine warms up it becomes redundant.
  8. #28
    Erskineville, NSW
    Octavias have a 1000W electric heater to immediately start warming the cabin while the coolant gets up to temp. One of the best "hidden" features on an Octy.
  9. #29
    Erskineville, NSW
    When I was doing my apprenticeship we had a Nubian fire tender fitted with a straight 8 Rolls Royce engine. It had an electric block heater & was permanently plugged into a GPO with a quick release extension cord arrangement. It meant that the engine was running reasonably well after 5 minutes use rather than the usual 20 minute warm-up period. Good stuff!
  10. #30
    Jun 2013
    Leichhardt, NSW
    Apart from making sure your glass is kept clean which always helps, could also be your interior filter. I always wondered why my air con was sluggish, demisting, etc.. pulled the interiot filter out and it was so black, like charcoal. put a new one in and wholah... good as gold. air flow much better, stronger, air con heaps colder, air through vents 200% better...HAve you checked it?
