While I agreed with many of the points you have made, I disagreed to some of them,
There could be a different DSG programming in the MK3 vRS compare to the MK2, hence the driveability is different, especially in D, an easy way to put this is, I found the torque output of MK2 vRS/MK5 GTI/Mk6 GTI/even the Yeti TDI are more sensible and linear to throttle input(this is regarding D only). This is however only my observation, someone might disagree.
As for the DSG tune, I found the following text from HP's website regarding their DSG tune product, they did mention a lowered S for better drive, and a D "gear closely matched to engine load & vehicle speed", I guess these have something to do with Shift timing, RPM and the torque output allowed in certain gears, I could be wrong though as I have never driven a car with such tune.
"DQ250 – K03 - Stock Power Level Vehicles (Driveability)
Our upgraded shift program solves a lot of the factory driveability issues
Modified torque limiter & torque capacity upgrade 450 – 500nm
Modified D - Drive mode for better drivability (gear closely matched to engine load & vehicle speed)
The S - Sport program is "lowered" for better usability
Faster shift response (especially for the older models)
All new software is based on the newest VAG version
Clutch shudder is dramatically reduced
Longer life of gearbox & clutch packs, less clutch slip"
And I strongly agree with you that I should start to use my paddle to request a down shift in D, it should make the overtaking much more smooth and pleasant.
You're all doing it wrong - you should be driving in E. Coasting FTW.
Well SillyBoy I'm afraid you have an appropriate forum name as far as this thread goes. Martin gave a very good response. Really you only have to touch a paddle button. Which is what this thread is about - you don't want to press a button!! Not much sympathy for you mate for this terrible problem. (I wouldn't want to be your barista! You would be very particular about your latte, I reckon.)
Each to their own I guess, and you Sir should calm down, I don't think I have offended you in any ways, Yes, I have a problem with my car's gearbox programming, so are some other members, and I am seeking advises for it, and I am sure someone out there is also seeking a way to overcome this. If you are feeling stressed with your live/work/relationship or what ever, take your anger elsewhere.
Calm down gents.
If you're new to a DSG gearbox it can be quite tricky and confusing, blurring the line between normal and faulty.
My current car is VW Jetta TFSI DSG with some decent go fast bits. If the car is new or if you've modified it, the car does need to learn and adapt to how you drive and this will obviously take some time. That being said, if you're driving style has been consistent for a significant amount if time/distance and you suddenly change behaviour, it will cause the car to stutter and react differently to your expectations. I'm not entirely sure how the new DSGs are programmed, but I've found that my DSG recognises and saves different behaviours to suit, and rightly so as I'm not the only one driving the car, and each driver would have different driving habits which the DSG would need to adapt to.
I considered the DSG tune a while back but came to the conclusion it wasn't worth it. Unless you're planning on significantly increasing the power output of your engine, by this I mean upgrading to a stage 3 ecu, bigger turbo, down pipe, intake, fuel lines, etc, you would definitely need to configure your DSGs software and hardware to tolerate the extra power and torque. If you're dealing with a simple Stage 1+, your DSG will be able to handle it and will need time again to reconfigure itself.
I would recommend either giving your car more time to adapt to your driving habits and styles (sensible and not so sensible), and if you're still having doubts, definitely take it to a VAG specialist or dealer to look into it.
I looked into the DSG flash but found it really hard to justify
The ECU flash was a great return on investment
(anybody that has spent money trying to get more power out of a car would understand that)
Thanks SillyBoy, why do you think I am agitated or angry? On the contrary, very relaxed - as laughing helps to relax me. I think you are the one stressing about your "problem". Some people have real problems. Like in Nepal.
But I do appreciate you are seeking advice and I will cease making fun of you. Enjoy the vRS and just give it some mate -hit the pedal and press the buttons when you need to, don't stress about it, just drive the damned thing and enjoy it.
The only issue I have with the DSG box (both DQ250 & DQ500) is how they slip the clutch while going up the hill at slow speed, forward or reverse (worse in reverse).
2011 Tiguan 125TSI - SOLD
2014 Race Blue Octavia RS 162TSI Combi
Check out my leather work ----> http://pedsnro.blogspot.com/
