The sensors are a sealed unit. If you use VCDS you can see what the sensors are reading in MM and see which one is incorrect and replace that one by removing the bumper. If you dont have access to VCDS then you might be able to work out which one via your screen display... usually its just a replace item unless water at the connector itself....VDUB...
