Results 1 to 10 of 14
Thread: Parking distance sensor problem
    Apr 2012
    Cherrybrook NSW
    I've recently started having problems with one of the front parking distance control sensors on my vRS (MY11) after driving in the rain. It would seem that water is getting into one of the sensors, causing the system to think an object is being detected at minimum distance (so continuous tone and red graphic on the screen).
    Has anyone else experienced the same thing and resolved it? Anyone know the structure of the sensors themselves or how the system is designed, ie, is each of the four sensors on the bumper a combined transmitter and receiver (this would be my guess), or are there two transmitters/two receivers. I do have a reasonable working knowledge of ultrasonic transducers and range finding.
    I'm thinking that water is somehow getting trapped in the sensor and effectively blocking it, causing an immediate 'echo' in the sensor, hence the minimum distance warning. Maybe there's some other gunk in there that needs to be cleaned out? FWIW, I've often wondered about the vulnerability of the PDC sensors to water/road grime/dust/insects.
    MY 22 Superb Sportline Wagon. Moon White.
    1985 BMW K100RS in JPS racing livery
    2019 BMW R1250GS Exclusive
    Mar 2013
    Brisbane QLD
    The sensors are a sealed unit. If you use VCDS you can see what the sensors are reading in MM and see which one is incorrect and replace that one by removing the bumper. If you dont have access to VCDS then you might be able to work out which one via your screen display... usually its just a replace item unless water at the connector itself....VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jun 2011
    Sydney NSW
    The sensors multiplex, so they are each a transmitter and receiver (although not at the same time).
    Do you get a graphic display indicating which sensor is triggering?
    Nov 2009
    Illawarra NSW
    My Mk.2 did it all the time. Didn't really worry me. Just get out and thump the offending sensor, to dislodge the water.
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
    Apr 2012
    Cherrybrook NSW
    Thanks guys for your replies.
    I have access to VCDS, however accessibility is usually inversely proportional to the occurrence of the problem! I'll try dousing the suspect sensor with a hose and check out VCDS. Although when I washed the car last Saturday, I'm pretty sure the problem didn't arise, but it did on Monday evening after driving home from work in the rain...
    From the display, indication is the inner RHS (the one next to the front number plate).
    I like the idea of a bit of 'percussive maintenance', I'll see if that 'fixes' it next time!
    It's a bit of a pest that the sensor has failed (or at least, its weather sealing has) just out of warranty.
    Jun 2011
    Sydney NSW
    Quote Originally Posted by k_rider View Post
    That should not be an issue. The dealers and VW will always try it on, but a component like this should not fail "just out of warranty". There is a reasonable expectation that the sensor should last longer.
    Press the issue with VW, and contact Fair Trading if necessary.
    Adelaide hills, SA
    Hmm, interesting. It could also be said that something poked it, or the high pressure cleaner was used to close damaging the sensor.
    So, I wouldn't be jumping on the high horse and shouting the "Fair Trading" thing.
    Jun 2011
    Sydney NSW
    Surely it could be argued that something fitted to a bumper should able to withstand the odd bump (which would be visible), and should be able to withstand some water pressure from a cleaner? It would be another thing altogether if the sensor was mounted inside the vehicle away from the elements.
    Apr 2012
    Cherrybrook NSW
    Yeah, I'd certainly aim for the 'gentle' approach with the dealer. And I'd have to agree something like this should last pretty much for the life of the car under 'normal' circumstances (ie not being hit or had high pressure jets of water aimed at it).
    FWIW, it's never been hit, to my knowledge anyway. There's always the chance it's been bumped whilst parked, but other damage would be evident. I've also never used a high pressure cleaner on the car, I'm always worried that the jet will find a stone chip or some such and start lifting paint! I've also taken care to avoid directly spraying at the PDC sensors even with a normal hose nozzle, as I was never sure how well sealed they are.
    Jul 2010
    There have been a nunber of discussions over at the briskoda forum regarding parking sensors playing up due to water or ice build up.
