No problems. As brad says just run a search for paddle shifter retrofit and you'll pull up a number of threads on the topic. There's even a few youtube videos if you're keen to DIY. I have personally installed a Golf R wheel into a Tiguan and it was relatively straight forward once the airbag was removed - which is a bit tricky the first time you do it.
If you can find a steering wheel with paddles that will fit your airbag you can save yourself some $. Something like this: OEM 5E0419091AF CWE Multifunction Steering Wheel for Skoda Octavia 3 with DSG Shift Paddles for 235.00 € - Å*koda
I used to use the paddles all the time until I had the DSG software tuned. After that I hardly used them at all as the car shifted how I wanted.
