Got the front & rear parking sensor kit. Rear went in ok. Wires routed up the left side of the car. Wondering if anyone knows where the front wire goes through the firewall? There's a spot down behind the battery. Any other suggestions?
Very hard cutting neat holes. I used an Irwin forstner bit (I think thats what they're called). Then cleaned it up with a Dremel sander bit and touch up paint. Holes ended up slightly too big and not perfectly round.
Also got a Tiguan style boot catch/camera which I can't put in yet as it requires cutting the hole larger (can do that though it's nerve wracking), can't find the connector for the boot lock which is different. Also need the backing/mounting cup for the rear of it- probably have to make one.
2008 Skoda Octavia Elegance TDI 4x4 wagon
Bluefin 132Kw/385Nm, Racechips Response Control, Haldex Performance controller, H&R anti roll bars, Koni FSD shocks, SuperPro control arms & ball joints, subframe & gearshift mods, Full Dynamat interior, Polk Audio sound, Columbus, Bluetooth, MDI, parking sensors, camera. BBS SR 18x8" w/ 225/40xR18. 3M Crystalline tint.
Fopund some Briskoda threads which helped
Not stuck with OPS / PDC installation - all fitted now. - Skoda Octavia II (2004 - 2013) - BRISKODA.net - The Skoda Forum and Community
PDC OPS advice - Skoda Octavia II (2004 - 2013) - BRISKODA.net - The Skoda Forum and Community
Managed to push the cable through the main firewall spot behind the glovebox (after cutting a small hole from inside the engine bay).
Beepers for the parking sensors go - left had B pillar, and if you take out the small top dash compartment, just down to the right of this, inside the dash, there is a spot with two holes ready (I used zip ties to hold them on).
There are Can HI & Can low wires to connect. Most people say to connect to the can gateway under the right side dash.
