Results 11 to 20 of 26
Thread: One month service/check up from dealership
    Adelaide hills, SA
    Quote Originally Posted by woofy View Post
    Yeah neither dealer I have had here in Melbourne did it. I even asked why there wasn't one when I got my first Skoda and they said don't change the oil until 12mths/15k as it's better to leave the run in oil there.
    Not such thing as running in oil in the vag cars.
    I've always changed oil in our cars at 1500km and then every 5,000-7,500km. we have on problems with our engines no oil leaks etc.
    So, no it's not better to leave the factory oil in the engine, because in 12 months when it gets drained it will be at least 18months old. I even had an older man who bought his Yeti brand new but almost 24 months old, that engine tasted new oil 3 years after the car was made.
    I had no issues either, that car is with my parents now at 9 yrs old. My Mk3 was 3mths old when I got it and seeing as it did nothing in that time until I drove it and in other countries that oil is made to last well beyond the schedules here I'm ok with waiting until the 12mth mark. Always each to their own, but the oil these days is quite different to not even 10 yrs back. If they run in them mostly too, you wouldn't be expecting iron filings floating about as much. If I did track days it would be entirely different.
    Adelaide hills, SA
    Yes, today's oils are different, they protect the environment first.
    Apr 2017
    belgrave victoria
    Would you advise a early change of oil for the new 135kw tdi?
    i have been told various things by different people its a long term ownership car (my baby now my real one is 19 lol) so i don't mind if it's the right thing to do
    It's going in soon to get a brake upgrade to golf r brake calipers and aftermarket pads and rotors i can get the change done then at same time it will have about 3000klm on it
    Thanks
    2017 Golf Alltrack 135tdi All options
    19 inch Brescia Wheels Golf R brakes front and rear
    Calipers painted Candy apple gold
    New rear sway bar and linkages
    Adelaide hills, SA
    Quote Originally Posted by Kachingg View Post
    Thanks
    Absolutely. Today's TDI engine run more EGR than ever before, more regenerations. I change engine oil and oil filter before summer and before winter. The engine oil in engine oxidase from the day it's put in the engine, unlike the oils in the transmissions which are better sealed.
    Apr 2017
    belgrave victoria
    Thanks very much i will organize a oil and filter change when im getting the brakes done
    Dec 2010
    Helensburgh
    No one gets oil tested so no one here can tell you whether it is a good thing or not. I ran a fleet of vans and trucks, all European and all Diesel, we changed on manufacturers recommendations, tested the oil and could have gone a lot further as the oils were all up to spec when changed. The truck supplier said they had run oils out to 75,000km with no detriment to the motors but they didn't like to as the mechanical checks were too far apart. My personal cars are all changed on specified manufacturer intervals and have never used oil between changes but I have never tested the oils, just observed the results.
    Jul 2010
    Quote Originally Posted by Ozsko View Post
    +1
    and i don't drive like a nanny.
    my previous car was a mk2 MY11 Octavia RS (TSI, DSG), running stage 2+
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Actually there were some people who used to post more often here that did with their 2008 118 Octavia and after a few changes found there was no point doing it earlier. They were fine.
    Adelaide hills, SA
    If you go into enough details, you'd have found out that the diesel engine oil for the trucks is bit different to VW504/507 oils or any engine oil that you buy in your local parts store. The trucks also have much bigger sumps than the cars, are driven 8 hours or more per day.
