VW says up to 500ml in 1000km is normal so I think you are doing well.
Halfway down the cross-hatched area isn't quite 500ml - probably closer to 400ml so that's a plus.
As woofy said, it's normal for new engines to use some oil - especially in the first 5000km & VWs tend to take about 15,000km to seal up (or the use copious amounts forever).
If the dealer is conveniently located then get them to top it up for free. Otherwise get some 504.00 or 502.00 spec oil & top it up.
BTW: VW have an unusual requirement for checking the oil - they want it done hot after letting the car sit for 10-20minutes. If the oil is hot it will read a little bit fuller.
You sound like you've got one of the better units. Lucky you!
