Its safe to jack your car on the sill there should be a small triange imprint on the sill thats the locating bit of were to jack if this is not there look along the sill and there will be 2 points that are different to rest if sill there you should jack use a block of wood so that it doesnt damage the sealent in any way and as of jack stands i allways put them on the lower arm towards the back on the front kind of looks like a upside down bridge and if the car has axel rear safe to just pop one on the axel if not and has irs pop one under were the spring sits theres a hole make sure you have the stand sitting in there shouldnt move
