Results 1 to 9 of 9
Thread: Octavia workshop efforts
    Dec 2012
    Sutherland Shire, Sydney
    Changed the engine oil today
    Was going to change the DSG oil also but didn't have a 14mm hex to remove the drain plug - will do it next weekend
    Tightened my front suspension arm mounts - they weren't very tight
    Hoping this will solve my creaking problem under high corning loads
    Installed the GoFastBits diverter valve update
    Makes a bit more noise - no performance difference noticed
    My car (2011) already had the updated VAG diverter so there was no need to replace it
    Installed the HPA lower interlock mount - red/soft one
    This has given me some mild vibrations in reverse and when accelerating from low rpm (below 2000rpm)
    It's almost perfect - so close - hoping I can live with it
    Nov 2010
    NSW
    Is that the same as the GFB Blowoff valve?
    2012 Yeti 77TSI, Candy White
    ydad.com.au: musings of a dad growing up - the blog.
    cbay.com.au: photography, video, design - creations.
    Dec 2012
    Yes it is the GFB divertor add-on
    GoFastBits stuff is for the Nissan 350Z
    Jan 2012
    hey didn't you tell me that would make zero difference when I said I installed one??
    and also, which arms did you re-torque up? I have that knocking sound. seems like something is loose when it shouldn't be. might take a visit to the hoist this weekend and go mad with the torque wrench.
    Dec 2012
    Quote Originally Posted by zei20t View Post
    Correct - and that's the outcome I've got - curiousity killed the cat
    I'll have to go hard over the macquarie pass
    Hmmm, a knock would be something different
    I had creaking sounds when cornering very hard and on change of transition from hard accelleration to hard braking
    I've tightened the two big bolts over the rear bush at the rear of each front control arm
    Jan 2012
    heheh the only reason why I installed one is for the spring pressure as my boost levels are above stock. I know there is no performance difference. flutters a little and makes a louder sound now
    ok, im still going over the car on the weekend - hopefully - to make sure nothing is loose. if you found something loose, then chances are most cars need going over.
    Jul 2013
    Caulfield, VIC
    I went for a turbosmart and while quite subtle in the car, it does make me smile while dosing next to a big wall, and turns civilian heads lol
    www.TheRapidWrench.Melbourne
    The convenient, professional and affordable mobile bicycle mechanic that comes to you!
    My RS build thread
    Erskineville, NSW
    Martin
    I know you are running a non-VW rated xw-40 oil for a bit more viscosity while on the track. Mobil1 have a VW502.00 0w-40 - might cover both bases? I bought some yesterday - $67 for a 5.1quart (4.8L) bottle
    Dec 2012
    Excellent - thanks Brad!
