Results 1 to 10 of 19
Thread: Octavia VRS Mk2 wind vibration between 75-90 kmph
    Oct 2012
    Augustine Heights, QLD
    As per the title I get what I believe to be wind noise when travelling between about 75-90. It's sort of humming sound that goes for about a second, quiet for half a second and repeats.
    It's not terrible but is noticeable and you can feel a light vibration through the floor and steering wheel as it hums.
    I think its probably the bbq plate looking front grill at a certain speed resonating or something and I'm thinking of buying a honeycomb style one from superskoda. Before I do just thought I'd see if its a common problem or something that someone else has noticed and if there's a simple fix?
    Jul 2010
    i haven't experienced this with mine.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Sydney Northern Beaches
    Mate I get it in my new VRS wagon, drives me mad. Happened only after I had a left hand front tyre blow out and changed the tyre. I believe it is caused by the tyres (Conti Sport) more than anything, or at least they are a significant contributor.
    Jul 2014
    Really do not think it is the grill, unless it is obviously loose. Have a look at the front under tray in case that is loose.
    Had similar noise and vibration problems at all speeds, issue varied with speed, road surface and/or synchronising of worn tyres on surface.
    The Mk2 OEM tyres blocks scalloped badly (Dunlops) after just 10k km.
    Had to have a re-alignment and fitted Yokohama tyres. Not as good grip but quiet for their whole life.
    Current Mk3 has Dunlop SportMaxx, but no issues so far.
    Jan 2010
    Bathurst, NSW
    Never had that issue on my Mk2. Agree with above, coming through the steering sounds like tyres?
    Jul 2010
    Quote Originally Posted by afterdarker View Post
    i had conti sport contact 2s on mine - no issues for me.
    Melbourne, Vic
    Quote Originally Posted by Aztech View Post
    No issue on mine with contact 2's. Never had the issue. Whisper quiet, even with Whispbar roof racks.
    I would suggest a wheel alignment. A LOT of cars are way out direct from the factory.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Oct 2012
    Hmmm maybe a wheels alignment is in order, I didnt think it was the tyres as I have replaced my wheels and tyres, had them done by a shop with a wheel balance but no alignment.
    The vibration is exactly the same with the new set up as it was with the original neptune wheels but I guess if its an alignment issue causing the problem then changing wheels wouldn't help.
    It still sounds a feels like its coming from the front, I may even try taking off the grill and taking it for a spin to see if it affects it at all.
    Quote Originally Posted by dArK5HaD0w View Post
    I just had a wheel alignment today at wheel and tyre specialist Spinning Wheels at Waterloo, Sydney. Still have the humming issue.
    Mechanic reckons it is almost certainly a wheel bearing, particularly as humming is much more noticeable on fast right handers when more pressure is on left front wheel (I previously had a left front blow out). So next step, I'm going to try to replace the wheel bearing under warranty.
    BTW I am not impressed at all with Conti tyres, I've had 2 blow outs requiring 2 new tyres and car has only done 4,000 km mostly urban driving in Sydney.
    Jul 2014
    Sounds like you have been enacting too many scenes from 'Fast and Furious' films.
    I have never experienced a blow out in 45 years of motoring. Picked quite a few punctures from nails and screws in tyres for sure as Australian tradies are pretty liberal about spreading them on the roads when they build a house.
