i haven't experienced this with mine.
As per the title I get what I believe to be wind noise when travelling between about 75-90. It's sort of humming sound that goes for about a second, quiet for half a second and repeats.
It's not terrible but is noticeable and you can feel a light vibration through the floor and steering wheel as it hums.
I think its probably the bbq plate looking front grill at a certain speed resonating or something and I'm thinking of buying a honeycomb style one from superskoda. Before I do just thought I'd see if its a common problem or something that someone else has noticed and if there's a simple fix?
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
Mate I get it in my new VRS wagon, drives me mad. Happened only after I had a left hand front tyre blow out and changed the tyre. I believe it is caused by the tyres (Conti Sport) more than anything, or at least they are a significant contributor.
Really do not think it is the grill, unless it is obviously loose. Have a look at the front under tray in case that is loose.
Had similar noise and vibration problems at all speeds, issue varied with speed, road surface and/or synchronising of worn tyres on surface.
The Mk2 OEM tyres blocks scalloped badly (Dunlops) after just 10k km.
Had to have a re-alignment and fitted Yokohama tyres. Not as good grip but quiet for their whole life.
Current Mk3 has Dunlop SportMaxx, but no issues so far.
Never had that issue on my Mk2. Agree with above, coming through the steering sounds like tyres?
2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
Hmmm maybe a wheels alignment is in order, I didnt think it was the tyres as I have replaced my wheels and tyres, had them done by a shop with a wheel balance but no alignment.
The vibration is exactly the same with the new set up as it was with the original neptune wheels but I guess if its an alignment issue causing the problem then changing wheels wouldn't help.
It still sounds a feels like its coming from the front, I may even try taking off the grill and taking it for a spin to see if it affects it at all.
I just had a wheel alignment today at wheel and tyre specialist Spinning Wheels at Waterloo, Sydney. Still have the humming issue.
Mechanic reckons it is almost certainly a wheel bearing, particularly as humming is much more noticeable on fast right handers when more pressure is on left front wheel (I previously had a left front blow out). So next step, I'm going to try to replace the wheel bearing under warranty.
BTW I am not impressed at all with Conti tyres, I've had 2 blow outs requiring 2 new tyres and car has only done 4,000 km mostly urban driving in Sydney.
Sounds like you have been enacting too many scenes from 'Fast and Furious' films.
I have never experienced a blow out in 45 years of motoring. Picked quite a few punctures from nails and screws in tyres for sure as Australian tradies are pretty liberal about spreading them on the roads when they build a house.
