Results 11 to 20 of 31
Thread: Octavia vRS Mk2 Oil Consumption Issues
    Jan 2012
    My CCZ used to use a hell of a lot of oil also. Only when they used whatever the dealer oil is.
    after finding some shonky work done to my car, skoda will never touch it again.
    Back to the oil problems, I changed brand. Now I top up twice a year with around 1L each time.
    I use a heavier weight oil - VW approved 5w40 - instead of the dealer supplied 5w30. I find it stays below 130degrees under high load (track days) and doesn't go a horrible thick black colour within 1000km. generally stays a very dark honey colour.
    Aug 2013
    Kings Langley, NSW
    Quote Originally Posted by zei20t View Post
    Also noticed the "long life" oil in our Superb looks shocking after no time at all. Why is this so?
    What brand are you now using?
    Erskineville, NSW
    Quote Originally Posted by notflyingscot View Post
    It's supposed to go black.
    According to the Lubrizol comparison site, 504/507 has more detergent & solids in suspension capabilities than 502/505 (for reducing sludge build-up).
    Zei20t's 5w-40 would probably be a 502.00 oil as you can't get 504/507 in a 5w-40.
    Sep 2012
    Is your Superb petrol or diesel? Diesels will generally discolour oil quickly but its not a reason to be concerned. I have Hyundai and Holden diesels in the family and they all do it but it has no effect. The oils are designed to hold the materials in suspension so it drains with the oil.
    Dec 2012
    Sutherland Shire, Sydney
    I think where the Penrite Enviro 5-40 falls short of the 504/507 rating is - it's not low SAPS
    Jan 2012
    Not relevant to us, we don't have diesel engines. 502/505 is enough for our engines.
    Jun 2014
    Quick update: It looks like they might be replacing the block on ours!? Just waiting on the confirmation from the dealer. He said 'they're replacing the engine' which I got him to clarify and he said a whole new block.
    Skoda Octavia v/RS - 2012 Petrol 6MT
    Jan 2012
    wow, that's good outcome. but did they mention why they are doing that?
    Apr 2015
    Five Dock, NSW
    Interesting - for me at least.
    My petrol 2007 vRS is using a lot of oil I have noticed.
    Maybe a litre every 1500kms?
    using VW approved oil.
    Would anyone else recommend using 5-40 such as Penrite Enviro ?
    I had assumed my PCV had been replaced but I'm not certain - would this be a sensible step to take?
    Not burning any oil that I have ever seen, nor dropping ANY when parked.
    Id be interested in anyone else's experience or suggestions. Thanks
    Erskineville, NSW
    Try some 502.00 spec 5w-40. It can't hurt.
