Results 1 to 10 of 15
Thread: Octavia using Oil
    Apr 2012
    Perth
    Octavia using Oil
    Just wondering how much oil everyone elses Octavia's use. I've done around 18,000km or so now in mine. Last service was at 15,000 and when I checked yesterday, the oil level was at low. Took around 1L to fill it back up.
    Checked the parent's Octavia, which has done ~8,000km and same deal. Sitting at low. Another Litre there.
    I've actually had to fill mine three times now since i've owned it. Approximately 1L each time, and whilst I realise new engine's tend to use a bit of oil, i'd say now at 18,000km it's no longer considered new enough to use oil. It's the first time the parent's one has required filling.
    Is this common or is there something wrong? I might start documenting my filling amount and KM's etc.
    Dec 2012
    Sutherland Shire, Sydney
    From 14,000km to 24,000 I put 2L into my one (2L 147kw)
    (I'm not overly concerned about it other than ensuring the engine is topped up regularly)
    Jan 2012
    mine does it too
    it always seems to need filling up a few thousand after a service. I rekon they fill it up midway, instead of to the high-line.
    unless its using a hell of a lot of oil, I wouldn't bother. it also depends on how you drive your car too, and probably how frequently.
    Oct 2009
    Mitchelton, Qld
    Yep, mine's done 12,000km and I've had to fill it up twice now.
    Apr 2012
    Perth
    Quote Originally Posted by zei20t View Post
    mine does it too
    I drive mine briskly. Not close to red-lining, acceleration usually around the 3.5k rpm mark.
    Parent's car is driven a lot gentler.
    Seems like it's a common thing, which sucks as the oil is not cheap
    Jan 2012
    I know what you mean, TBH my wifes 500 uses a bit of oil too. coming from Japanese cars that barely use a drop, I put it down to European engines. that's my completely un-investigated and biased opinion
    Individual engines vary a lot too.
    My A3 never used any oil.
    One colleague has a MkV GTi that doesn't use much at all.
    Another colleague has a B8 A4 that drinks the oil like its got a bad habit.
    Mar 2013
    Brisbane QLD
    VW say 0.5L 0f oil every 1000km is the limit of useage... over that you may have a issue.. it used to be 1L every 1000km.... set your oil level to max on the dipstick.. reset your trip meter and in 1000km recheck the level... should not be more than 0.5L to top up back to max...VDUB...
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Gosford Central Coast NSW
    Quote Originally Posted by deeps View Post
    You really should, when asking for advice of this kind, tell us what engine your octavia has.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Erskineville, NSW
    Mine doesn't use oil. 1.8TSI EA888 engine. Had it from new & now done 112,500km.
    oil changes done at:
    15
    30
    45
    60
    75
    82.5
    90
    97.5
    105
    112.5
    probably half were done with 502.00. Always 5w-30. various brands - valvoline, castrol, shell & whatever my service guy uses.
    If you are having minor consumption issues after 15,000km (<1l/15,000) then I'd recomend you try
    Mobil 1 ESP 5w-30 (504.00/507.00) $14/950ml
    Mobil 1 ESP Formula 5W-30
    or even Mobil 1 0w-40 (502.00) $11.50/950ml
    Mobil 1â„¢ 0W-40
    try this place for cheap mobil 1
