Originally Posted by
wfdTamar
13-pin round Euro
1. left indicator
2. rear fog
3. earth return
4. right indicator
5. right tail & sidelights
6. stop lights
7. left tail & sidelights & number plate
---------(pins 1-7 are the same as a flat 7-pin connector)---------
8. reverse
9. permanent 12 volt (interior lights and charging)
10. auxiliary, ignition switched 12 volt (fridges)
11. earth for pin 10
12. signal connector (not used on VAG cars)
13. earth for pin 9
Not true.
Flat-7's, at least in Aus, are as follows:
1. LH indicator
2. Reverse (Often not used)
3. Gnd
4. RH indicator
5. Elec. brakes
6. Brake
7. Parkers
Most of the time, pin 2 is used for +12v.
At least, thats how our vehicles/caravans/trailers have been wired up since I can remember.
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
