Results 1 to 10 of 13
Thread: Wheels. 19 inch vs 18 inch
    Sydney Northern Beaches
    I have 18s on my Octavia wagon. I could have got 19s from new, indeed they were on the car at the dealers, but I thought the ride was very harsh with 19s. Now I am looking at some new wheels (VMR V701) in 19 inch and weighing up beauty vs utility. Bit like considering a new girlfriend! Ha ha.
    What are opinions on 19s vs 18s? Mine is a work vehicle, will do about 25,000 km a year, mix of suburban and interstate.
    Oct 2009
    Mitchelton, Qld
    What's the weight difference including tyres? Heavy rims/tyres on the front will give you more axle tramping.
    19s for looks (subjectively), 18s for ride, performance, price, ie everything else.
    Erskineville, NSW
    Stick with 18s
    get either 7.5" or 8" but get a slightly more aggressive offset
    Buy something around 8kg.
    Dec 2012
    Sutherland Shire, Sydney
    Fully agree!
    Also choice and price of tyres
    The 225/40/18 is a very common size where as 225/35/19 has less options and higher prices
    Then there is the higher risk of pot holes hitting your rim as a 35 profile is getting very skinny
    Apr 2014
    Melbourne, VIC
    I have the 19" on mine, and while it looks good, I hit a fairly shallow pothole a couple of weeks after delivery and damaged two tyres. I think the 18" with the higher profile would've had a bit more compliance.
    .: MY15 Octavia vRS Wagon | 2.0T 162kw DSG | Moon White | Pano Roof | 19" Black Pack | Canton Audio + RVC :.
    Erskineville, NSW
    If you run 19s then you have to increase pressures to compensate for the lack of free volume within the tyre carcass.
    Jan 2011
    Brisbane - QLD
    18" tyres paid $690 for potenza s001 in 235 40 18 with 4 for 3 special.
    a friend paid $1200 for potenza re003 in 235 35 19 with the same 4 for 3 special.
    Sent from my GT-I9506 using Tapatalk
    MINI Cooper S Clubman - FWD
    brisbane
    Quote Originally Posted by donweather View Post
    i'm just checking if this is in relation to the tyre question or the potential girlfriend question?
    on a serious note i changed from 18's to 19's and noticed a massive difference in ride comfort. that said it's probably ok for 80% of the time so up to you if you are prepared to suffer a bit over poor road surfaces...
    Apr 2014
    Melbourne, VIC
    Yep, I'm running 38F 37R. The dealer always drops it down to 34/33 when it goes in for anything.. too low for 19's IMO.
