There's a few DIY threads around, however if you were concerned about removal/installation of an airbag you could take it to a reputable workshop to do the work. All that is involved is disconnect the battery, unclip the airbag, undo the bolt holding the steering wheel on, remove the wheel and then reverse the procedure to install the new steering wheel. There is a small bit of coding which takes all of 2 minutes. Maximum 1/2 an hour in a good workshop including a test drive to clear any faults.
