View Poll Results: What Filter do you use?
Voters
12. You may not vote on this poll
  • CAI (Carbonio/apr ETC)
    8 66.67%
  • Panel Filter (K&N/BMC etc)
    4 33.33%
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 64
Thread: Performance panel filter or CAI? Tell us what you use
    Oct 2010
    Gold Coast, QLD
    Just wanted to ask people out there what they use.
    Also a discussion to is there really any benefit on CAI as apposed to a hi end Panel filter
    My11 Octavia VRS Tsi
    Rockford splits in front - Tinted Windows - Viezu Perfomance tune - K&N Panel filter
    Realise this is for Octavia but closely related. In the process of looking at CAIs at the moment and will be going that route over a replacement filter.
    An interesting test series was conducted in the USA on the golfmk6 forum comparing stock to filter to CAI.. obviously other factors can impact these results but interesting all the same.
    Technical Understanding: Intakes: Stock vs. Drop In vs. Aftermarket - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
    Apr 2010
    Nice read
    I've added a K&N reusable filter (although I've not checked if it's still there since my most recent service) and there's hardly any noticeable difference - probably more of a placebo. I never tested fuel economy differences.
    I had K & N in my 323 Sports Edition and it did make a difference both in driving and at the dyno....but would not bother with the RS as they were an art to clean properly and you always wonder whether the oil fouls up sensors etc.
    Erskineville, NSW
    neither
    have tried a few oiled panel filters in the past (PiperCross & FinerFilter) and neither made any noticeable difference. I've read enough about the OEM filter & airbox to believe it is efficient enough for the amount of power these cars have.
    I would be tempted to try a non-oiled cone filter if I could get something like a twintake.
    I also believe that if you could get more cold air into the OEM box it would be an improvement too.
    I'm kinda over the whole change the intake thing, most CAIs or SRIs seem to just be more pain than gain and depending on how low you put them, seem to suck up water and hydrolock more often than not. Unless you live in Tassie, most of the time the road temps are hot here so moving the intake away from the engine bay doesn't really help a lot. A dyno run won't accurately show the effect of hot road temps either as the car is sitting under cover, half the time in A/C.
    That contradicts the findings in the US testing I linked above which definitely showed improvements with a well designed CAI over the stock system - ie. one which is sucking in outside air.
    Maybe not in extra power generated, my take was it was more about improving power across the rev range. They were certainly critical of the stock design which was about reducing noise more than anything.
    However not trying to claim the US test is right, just one possible take on things - I'm certainly no expert, just like gathering multiple points of view and learn more about my car.
    Dec 2012
    Sutherland Shire, Sydney
    I agree there are improvements, but they are very small
    Where these small improvements become more important/noticeable is when you have modified the engine to produce more power
    If you are keeping the ECU/Engine/Exhaust stock I would not waste money on a high end CAI (panel filter - yeah sure)
    I updated my Octavia VRS TSI ECU to ECU stage one - the top end was worse than stock
    It ran out of puff in the 5500~6000 rpm range and took a long time to rev out after that
    While I have no evidence as to why this was happening,
    looking a the review Dutch77 has posted, the CAI has improved MAF and boost control
    (Although, the boost control with Carbonio Stage 1 looks worse that stock over 6400 rpm! Make sure you get the full kit)
    To get around this I was short shifting and driving off the large torque increase that Stage1 gives
    But ultimately I decided to do something about this...
    I got the big exhaust down pipe, StageII ECU update and full Carbonio kit
    (The difference between ECU Stage I and II is small - Stage II came as part of the exhaust upgrade package)
    This totally addressed the issue and made me very happy
    The engine now revs out to redline without dragging it's heals
    The guys at the shop were very impressed,
    they rang me to say the work was complete and "your car goes like hell now"
    They even had the professional customer care to tell me to watch out in the wet
    as they expected it to torque steer all over the place (it does, change driving style in the wet)
    The downside for some will the noise from the CAI
    During normal driving is not much different
    When you open the throttle you will get whistle noises, intake noise and diverter valve noise
    I also get more noise from the large exhaust down pipe
    These are all modern turbo noises, not wonderful in my view (not like old style Webers and Camshaft noises)
    Jan 2012
    Quote Originally Posted by Martin View Post
    I can guess what was happening. With the intake and tune power was being delivered sooner, however it hit a wall higher in the rev range due to the restriction of the exhaust. You said it had more torque which also support this.
    With the new exhaust and free flowing intake, the new tune could make the most out of your current set up.
    The limiting factor now is probably either the intercooler, turbo or fuel system or a combination. Not sure what these are all rated to.
    A free flowing intake will make a difference, whether you can feel it with the seat of the pants dynometer, not sure.
    On our other car I bolted on a cat back exhaust just for a better sound and it made just over 10% more power atw. This power is all higher in the rev range so hard to notice on the street. The noise on the other hand...
    Agree, webbers and lumpy cams sound great, but you can't switch between tunes quite as easily when it starts raining and the cold start can be an issue.
    Dec 2012
    Quote Originally Posted by Weekend-Warrior View Post
    Yes - that is a nice summary completely in line with what I think is going on
    The TSI fuel delivery is solid (unlike the TFSI)
    I won't be chasing any more power, it's got heaps
    Fully agree, the wonderful thing about a turbo charged car is the fuel savings off the throttle versus performance on throttle, much wider fuel and power range than a normally aspirated car
