I believe the 169 is still using the same 6 speed wet clutch DQ250 DSG as in the previous gen.
The RS245 will be using the new 7 speed wet clutch DQ380 which is also in the 7.5 Golf R. It's a higher rated box and has an extra cog. Looks like the Golf GTI and the standard Octy RS are keeping the "older" 6 speed wet clutch for a little longer.
It's only the lower power/torque engines that are matched up to the dry clutch DQ200 7 speed DSG.
