Results 1 to 9 of 9
Thread: Octavia RS intermittent bad idle Help
    Sep 2011
    Hi
    my 2009 rs has just started having bad idle, has conked out once, not good.
    the warning light comes and stays on, but then turns off, everything seams good.
    then it starts the jumpy idle again. error code p2015 (likely intake manifold) the big issue is it comes and goes
    doesn't matter if the engine is hot or cold.
    ive only had one opportunity to look nuder the bonnet once when it was doing it. i could be wrong but i thing there was a sucking sound (vacuum leak). i might be wrong . i'll have to try listen again if/when it starts again.
    I'm not too keen on taking it to Skoda as they charge $180.00 per hour, and if not playing up at the time they have it, diagnosis will be cash down the drain.
    i've seen plenty threads but none seam to come and go like mine.. any thought >>>????
    1990 MK2 Golf GTI
    Nov 2009
    Illawarra NSW
    Nearly bet your house on carbon build up in the head. How many kms has it done ?
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
    Oct 2009
    Mitchelton, Qld
    Quote Originally Posted by Antiplastix View Post
    That's what I would have said also but the fact it's intermittent and doesn't matter if it's hot or cold is not pointing to carbon on the intake manifold IMO. You could take it to these guys as they diagnosed my wife's 2009 Tiggy problem spot on (carbon intake manifold build up).
    https://www.bavariamotortuning.com.au/
    Sep 2011
    Answer! The intake manifold has failed. The control runner pops out, if I keep it under about 3000rpm it doesn't seem to pop. I've done a crude fix to keep it from popping whilst not inhibiting full functionality. It will do just fine until I can get the manifold replaced.
    Although seeing is works so well, in in no rush.
    Merry xmas
    1990 MK2 Golf GTI
    Jul 2010
    I've got a MY11 TSI - had the intake manifold replaced 2 weeks ago.
    Same error code - p2015.
    Although my idle was not rough nor did it clonk out.
    Nov 2009
    Illawarra NSW
    Bugger, there goes my house.
    Sep 2011
    I think the the delete kit is only for fsi not tsi
    1990 MK2 Golf GTI
    Sep 2011
    Finally installed the new intake manifold ( latest revision of the manifold part number ending with BH)
    Now that's 10hours I'll never get back
    Due to the coolant pipes, the 10m triple square bolt was the most challenging part of the replacement.
    All good now.
    1990 MK2 Golf GTI
