Hahaha thats cool...... I don't think I have been able to do a fuel economy test in 10,000km.... too much fun under the right foot.
So, today I picked up my car from the shop having had a fair amount of work done to it:
-Carbonio cold air intake box and intake tube
-APR 3" exhaust down pipe and high flow rate catalyst
-APR ECU Stage II firmware
-APR (VMR?) Roll bars
-VMR springs (20mm lower)
-Supaloy lower control arms
When I bought the car, I drove 39km from the dealer to the shop and had it flashed to Stage 1
This is probably all I would encourage most people to do - it gave great performance and value for money
But I wanted more and there are a few issues
The top end power was a little worse than stock and tapered off early,
as such I was short changing and driving on the big torque boost you get
I thought it would be really nice if the power went all the way to red line
Hence I went for the cold air intake and 3" exhaust for breathing + ECU Stage II
(The Stage II power/torque is only a bit more than Stage 1 - so why not?)
The throttle was very non linear (stock is a bit like that also)
Low throttle opennings were smooth - good for when wife & parents are passengers
But once you get past 40% it was like flicking a switch - instant change of power/aggression/noise/urgency
So after these latest engine changes, it's very different
(The guys at the shop commented on how quick it the car is)
The engine has more torque from lower down, it's got seemless pulling power everywhere
The engine now revs out to redline without any sense of a slowing accelleration rate (or asma)
The throttle is much more linear - but still very easy to drive normal and smooth
It does not have the alarming night and day performance change - it's much more progressive
The traction control used to be a bit harsh and counter productive (by design I guess)
The traction control is now smoother and unintrusive
I now keep my foot in the throttle and let the TC deal with the problem
Fast starts are easier - a chirp from the wheels and then we fly away at a surprising rate
I can only assume this because the torque is smoother and available at lower RPM
(Stage I used to come on power hard at 2500 and break traction)
Maybe the supaloy control arms are also making fast starts better?
I can break traction in 2nd gear - but no axel tramp as yet (early days)
The downside to going Stage II??? It clearly not for everybody
The rasping exhaust sound is louder and somewhat unpleasant
This is both from the rear and front due to the large exhaust downpipe
You can at times get engine resonsance from engine braking as you slow down
This can be avoided by manually changing down early - if you can be bothered
You now hear inlet air noises also - sucking and whistles
These are only an issue when actually using the power
although the engine idle may be a little louder due to the large exhaust downpipe
The Octavia fundamentally handles well and does not have much roll - until you really load it up
The wheels are bit thumpy/noisy over rough stuff
While the ride is pretty nice, it's not soft or smooth, pretty good compromised really
yet it's also not well connected until you have a decent/constant cornering load
So (given this is our second car - my useful fun thing) I decided to try new springs and roll bars
The car looks better with the guards 30mm above the tyres
So it's not obviously lowered and won't attract undue attention (sleeper!)
The handling is certainly better - really well connected to the road
The cornering is flatter and inspires confidence/trust
The damping seems better - no more thumps or bounces - although you do feel all undulations
(Less weight with the supaloy control arms? Wheels are much lighter than stock also)
Again, the downside, you feel most ripples in the road surface
Driving down poor roads may irratate after a bad day at the office
It's certainly imparted a firm edge to the ride that family folk may not warm to
The supaloy control arms have a bit more caster,
the car drives dead straight for ages with no steering guidance
Initial turn in is more crisp and direct - need more km to comment further
On the stock ECU mapping I get ~565km from a tank
On the APR Stage I ECU mapping I get ~515km from a tank (travelling to/from work wth a little fun)
That was great, happy to leave it in the APR fun mode all the time so the power is available all the time
So - what will happen to the fuel economy with the APR Stage II ECU mapping?
Let me get one "fun" tank out of the way before I test the fuel economy
2011 MK6 GTI ED35
APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
Awesome little write up!... I don't spose APR does TDI stage 2, do they?![]()
2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
Not including hers...
2018 Ralyee Green RS wagon. Fully optioned.
Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
Yes mate, I'll be there on the 2nd
The interesting test will be Saturday when I take the wife and parents to Kiama
Let's see if she notices (or complains about) any difference in the car
I did encounter some messy torque steer this morning
(Lane change from stationary with too much throttle)
When I got the car last night I was a little surprised at how firm the ride was
I had been driving a very soft BMW 735 for 3 days - the contrast was huge
But driving to work this morning, the car did not feel unduly hard/stiff
I am seldom using full throttle - just don't need to - it goes hard long before reaching full throttle
(In another thread I see people naming their car - I want to call my VRS "Lethal Weapon")
The Carbonio carbon air intake is a work of art
I reckon StageI ECU and the Supaloy controls arms would be a good upgrade plan
Going past that you need to be a focused/enthusiastic driver with a keen interest in motorsport
The air inlet, exhaust and StageII ECU have really improved the engine performance to a wonderful level,
with some undersirable cabin noise from the intake and exhaust - you need to be able to live with that
That sounds awesome Martin. You should have a chat to my bro about similarities / differences with APR Stg2 on his Mkv GTI. We should be coming along on the 2nd.
How much do the supaloy control arms change the driving feel? I've always been interested to see if they're a worthy upgrade to the handling.
2012 Yeti 77TSI, Candy White
ydad.com.au: musings of a dad growing up - the blog.
cbay.com.au: photography, video, design - creations.
Sounds great! Are you worried about volding the warranty?
MY12 - Octavia vRS Liftback, Brilliant Silver Metallic - Revo Stage 2
MY12 - Superb Ambition Wagon, Black Magic pearl effect
http://www.auskoda.com
