Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Octavia now at Stage II ...
    Dec 2012
    Sutherland Shire, Sydney
    So, today I picked up my car from the shop having had a fair amount of work done to it:
    -Carbonio cold air intake box and intake tube
    -APR 3" exhaust down pipe and high flow rate catalyst
    -APR ECU Stage II firmware
    -APR (VMR?) Roll bars
    -VMR springs (20mm lower)
    -Supaloy lower control arms
    When I bought the car, I drove 39km from the dealer to the shop and had it flashed to Stage 1
    This is probably all I would encourage most people to do - it gave great performance and value for money
    But I wanted more and there are a few issues
    The top end power was a little worse than stock and tapered off early,
    as such I was short changing and driving on the big torque boost you get
    I thought it would be really nice if the power went all the way to red line
    Hence I went for the cold air intake and 3" exhaust for breathing + ECU Stage II
    (The Stage II power/torque is only a bit more than Stage 1 - so why not?)
    The throttle was very non linear (stock is a bit like that also)
    Low throttle opennings were smooth - good for when wife & parents are passengers
    But once you get past 40% it was like flicking a switch - instant change of power/aggression/noise/urgency
    So after these latest engine changes, it's very different
    (The guys at the shop commented on how quick it the car is)
    The engine has more torque from lower down, it's got seemless pulling power everywhere
    The engine now revs out to redline without any sense of a slowing accelleration rate (or asma)
    The throttle is much more linear - but still very easy to drive normal and smooth
    It does not have the alarming night and day performance change - it's much more progressive
    The traction control used to be a bit harsh and counter productive (by design I guess)
    The traction control is now smoother and unintrusive
    I now keep my foot in the throttle and let the TC deal with the problem
    Fast starts are easier - a chirp from the wheels and then we fly away at a surprising rate
    I can only assume this because the torque is smoother and available at lower RPM
    (Stage I used to come on power hard at 2500 and break traction)
    Maybe the supaloy control arms are also making fast starts better?
    I can break traction in 2nd gear - but no axel tramp as yet (early days)
    The downside to going Stage II??? It clearly not for everybody
    The rasping exhaust sound is louder and somewhat unpleasant
    This is both from the rear and front due to the large exhaust downpipe
    You can at times get engine resonsance from engine braking as you slow down
    This can be avoided by manually changing down early - if you can be bothered
    You now hear inlet air noises also - sucking and whistles
    These are only an issue when actually using the power
    although the engine idle may be a little louder due to the large exhaust downpipe
    The Octavia fundamentally handles well and does not have much roll - until you really load it up
    The wheels are bit thumpy/noisy over rough stuff
    While the ride is pretty nice, it's not soft or smooth, pretty good compromised really
    yet it's also not well connected until you have a decent/constant cornering load
    So (given this is our second car - my useful fun thing) I decided to try new springs and roll bars
    The car looks better with the guards 30mm above the tyres
    So it's not obviously lowered and won't attract undue attention (sleeper!)
    The handling is certainly better - really well connected to the road
    The cornering is flatter and inspires confidence/trust
    The damping seems better - no more thumps or bounces - although you do feel all undulations
    (Less weight with the supaloy control arms? Wheels are much lighter than stock also)
    Again, the downside, you feel most ripples in the road surface
    Driving down poor roads may irratate after a bad day at the office
    It's certainly imparted a firm edge to the ride that family folk may not warm to
    The supaloy control arms have a bit more caster,
    the car drives dead straight for ages with no steering guidance
    Initial turn in is more crisp and direct - need more km to comment further
    On the stock ECU mapping I get ~565km from a tank
    On the APR Stage I ECU mapping I get ~515km from a tank (travelling to/from work wth a little fun)
    That was great, happy to leave it in the APR fun mode all the time so the power is available all the time
    So - what will happen to the fuel economy with the APR Stage II ECU mapping?
    Let me get one "fun" tank out of the way before I test the fuel economy
    Jan 2013
    Brisbane, The Gap
    Hahaha thats cool...... I don't think I have been able to do a fuel economy test in 10,000km.... too much fun under the right foot.
    2011 MK6 GTI ED35
    APR Stage 2 / APR HPFP / APR Turbo back Exhaust / VWR Intake / Ohlins shocks / HP Sway Bars / HP Control Arms
    MY13 AMAROK HIGHLINE / Oettinger tuned / ATS Wheels
    Bowral, NSW
    Awesome little write up!... I don't spose APR does TDI stage 2, do they?
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Feb 2010
    Camden NSW
    Quote Originally Posted by Martin View Post
    Sounds awesome Martin!
    You have given me a bit to think about! (and plan??)
    Cant wait to see and hear it on the 2nd!! you are still coming right??
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Dec 2012
    Yes mate, I'll be there on the 2nd
    The interesting test will be Saturday when I take the wife and parents to Kiama
    Let's see if she notices (or complains about) any difference in the car
    I did encounter some messy torque steer this morning
    (Lane change from stationary with too much throttle)
    When I got the car last night I was a little surprised at how firm the ride was
    I had been driving a very soft BMW 735 for 3 days - the contrast was huge
    But driving to work this morning, the car did not feel unduly hard/stiff
    I am seldom using full throttle - just don't need to - it goes hard long before reaching full throttle
    (In another thread I see people naming their car - I want to call my VRS "Lethal Weapon")
    The Carbonio carbon air intake is a work of art
    Dec 2012
    Quote Originally Posted by Tigger View Post
    I reckon StageI ECU and the Supaloy controls arms would be a good upgrade plan
    Going past that you need to be a focused/enthusiastic driver with a keen interest in motorsport
    The air inlet, exhaust and StageII ECU have really improved the engine performance to a wonderful level,
    with some undersirable cabin noise from the intake and exhaust - you need to be able to live with that
    Nov 2010
    NSW
    That sounds awesome Martin. You should have a chat to my bro about similarities / differences with APR Stg2 on his Mkv GTI. We should be coming along on the 2nd.
    How much do the supaloy control arms change the driving feel? I've always been interested to see if they're a worthy upgrade to the handling.
    2012 Yeti 77TSI, Candy White
    ydad.com.au: musings of a dad growing up - the blog.
    cbay.com.au: photography, video, design - creations.
    Dec 2012
    Quote Originally Posted by cbay View Post
    We would wax lyrical about it all day!
    So far I only have limited observations:
    -Massive reduction in axle tramp issues
    -Tracks dead straight on it's own for miles
    -Initial turn in is more crisp/responsive
    Jan 2012
    Sounds great! Are you worried about volding the warranty?
    Aug 2012
    Quote Originally Posted by Weekend-Warrior View Post
    I was about to ask the same question
    MY12 - Octavia vRS Liftback, Brilliant Silver Metallic - Revo Stage 2
    MY12 - Superb Ambition Wagon, Black Magic pearl effect
    http://www.auskoda.com
