ok, Dave and I were discussing this the other night and it was doing our heads in (which is not that difficult for me at least) but anyway ..
I got the following info off wikipedia (which may or may not be correct of course) .. can anyone confirm the truth of it or otherwise???
What has me confused is that the Octavia Mk2 engine specs (BWA vs CCZA engine codes) don't exactly correlate with the specs of said engine codes as mentioned in the EA113 and EA888 specifications, and to make things worse the specs shown on the skoda.com.au brochure are some kind of weird combination of both, wtf?!?
the reason I decided to look this stuff up in the first place is because I came across the following post from an APR dude on vwvortex:
"Given the low cost of the stage 3 kit for the TSI compared to the FSI I would have jumped on the Stage 3 over the K04. I've driven both and I like the stage 3 because the power does not drop off up top at all. BTW I have a k04 on my FSI and after being in the TSI stage 3, I want it on my car but alas, I have an FSI. You guys have it so easy, clean and cheap!"
VWVortex.com - Stage 3 dyno graphs / mini review
Octavia Mk2 (Typ 1Z) (2004–present)
2.0 TFSI vRS (BWA) 10.2005 – 10.2008
1984 cc 16v DOHC Turbocharged Fuel Stratified Injection
200 PS (147 kW; 197 bhp) @ 5,100–6,000
280 N·m (207 ft·lbf) @ 1,800–5,000
2.0 TSI vRS (CCZA) 11.2008 – present
280 N·m (207 ft·lbf) @ 1,700–5,000
2.0 R4 16v TFSI 125-199kW (EA113)
0.9 bars (13.1 psi) boost water cooled BorgWarner K03 turbocharger (K04 on 169 kW upwards)
147 kilowatts (200 PS; 197 bhp) @ 5,100-6,000 rpm; 280 newton metres (207 ft·lbf) @ 1,700-5,000 rpm — AXX, BWA, BWE, BPY (North America) — Audi A4 (B7), Audi A3 (8P), 2006 Audi TT, VW Passat (B6), VW Golf Mk5 GTI, VW Jetta Mk5 GLI, SEAT León FR Mk2, SEAT Altea, SEAT Toledo Mk3, SEAT Exeo, Škoda Octavia (1Z) vRS
199 kilowatts (271 PS; 267 bhp) @ 6,000 rpm; 350 newton metres (258 ft·lbf) @ 2,500-5,000 rpm — CDL — Audi TTS, Golf R (Europe)
notes - the 169 kW and higher versions have stronger pistons and gudgeon pins, new rings, reinforced connecting rods, new bearings, reinforced cylinder block at the main bearing pedestals and cap, new lightweight aluminium-silicon alloy cylinder head for high temperature resistance and strength, adjusted exhaust camshaft timing, increased cross-section high-pressure injectors, 1.2 bars (17.4 psi) (value only valid for Audi S3(8P)) boost pressure K04 turbocharger with larger turbine and compression rotor (S3, Cupra, GTI Edition 30), of which some components are NOT shared with the lower output variants
was winner of the "1.8-litre 2.0-litre" category for four consecutive years in the 2005, 2006, 2007 and 2008 annual competition for International Engine of the Year
2.0 R4 16v TSI/TFSI 132-155kW (EA888 )
BorgWarner K03 water-cooled turbocharger
155 kilowatts (211 PS; 208 bhp) @ 5,300-6,200 rpm; 280 newton metres (207 ft·lbf) @ 1,700-5,200 rpm — CCZA, CAWB: VW Golf Mk6 GTI, VW Scirocco, VW Passat B6, VW CC
was winner of the "1.8-litre 2.0-litre" category in the 2009 annual competition for International Engine of the Year.
