Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Octavia non-FL v's FL engine specs
    Jul 2011
    Burwood, VIC
    thanks guys, some great info there. It's good to know what's actually under the bonnet : )
    darkshadow, on a side note, do you know if the acceleration rattle affects recently-delivered Octys and GTI's as well?? ie. should I put my order in for a clip before I receive the car next month?, hehe
    - 2006 Audi B7 RS4 sedan, black, APR supercharged
    - 2008 Audi B7 RS4 avant, silver -- 2002 Audi B5 S4 vagwagon, ming blue
    - MY12 OCTAVIA vRS Wagon | DSG | revo | Eurojet DP | Milltek catback | KW V3's | 18x9 -45 Rays VR G2's | 18x8.5 -45 A8 Flat Fives | Kumho KU36 245/35 | Superpro ALK | ECS Stage 3 BBK | ECS eng mount | ITG Maxogen | DTM front splitter | SB
    Jul 2010
    Quote Originally Posted by bluefrog View Post
    it still affects recently delivered gtis. i haven't heard much from the vrs paddock.
    though, not all have the same intensity. mine for example is not noticeable unless u listen out for it. even the techo could not hear it.
    the noise it usually makes is quite loud. as someone else here described, "like dragging a metal cage behind the car"!!!
    as for the vw supplying the clip & installing it under warranty - from wat i've noticed, less than 3% have actually had the clip delivered and installed. the rest have been waiting for weeks upon weeks, with no eta in sight. its ridiculous how vw aus is treating this.
    because it does not damage/hamper/fault the engine in anyway, its not recall, nor is it of any urgency for them.
    u can try ur luck with getting urs put in under warranty. with mine, skoda aus refused the warranty stating the tpi did not apply to skoda vehicles. my dealer, out of goodwill, got my car looked by the vw techos. no luck with them either - "its not a vw".
    they (vw/skoda aus) fix things based on the badge of the car, not by the actual parts in the car, which belong to the same parent company.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
    Guys, can someone tell me what the air filter (engine) code is for a 2012 Octy VRS FL CCZA or where I can find it ?
    Are there different filters between the TFSI and TSI ?
    I'll check the manual tonight when I get home. Cheers.
    RS
    R
    Jul 2010
    Quote Originally Posted by Tuan View Post
    i'm fairly certain there are differences with the air filters between the TFSI and TSI engines.
    i don't have part numbers though. will c if i can find them later tonight.
    Thanks mate .. I need to also take a look in my manual to see that page with the piece of paper with the codes/numbers.
    Mines should be the TSI CCZA (08-12) as opposed to the TFSI BWA (05-0 .. damn it's hard to find things on google nowadays because this is too much information !
    my guess it that it should also be able to use the mk6 Golf GTI air filter..
    RS
    R
    Erskineville, NSW
    If it's a TSI then they all (TDI / TSI) use the same filter.
    Your engine is a TSI - its says so on the engine cover if you pop the bonnet. Your air filter is a rectangular shape.
    The TFSI is the older engine used in the pre face lift Octavias (as well as Mk5 Golf GTI's etc) and its air filter is also rectangular, but one corner is cut off on an angle.
    Cheers guys .. noted about the cut corner TFSI filter (which was pre FL).
    It's so much easier to just pull out the air filter and look at the part number on it just hard to do when I am sitting in the office and it's dark and cold once I get home fr work.
    This m6k looks about right .. https://www.youtube.com/watch?v=tSAi039F7hU
    Think I found the bastard -http://www.skodaparts.com/product/air-filter-octavia-golf-turan-30047
    Mann Filter - C 35 154
    K&N - 33-2865
    RS
    R
    K&N - 33-2865
    Mann Filter for your car from a local seller:
    https://runautoparts.com.au/vw/audi-...er-c35154.html
    Winner cheers.
    RS
    R
