Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
Thread: Octavia at MRT Track Day - Marulan
    Dec 2012
    Sutherland Shire, Sydney
    Firstly, a huge thankyou to the MRT Team for hosting the day and providing both technical advice and driving tuition - fantastic job guys (really nice bunch of blokes to mingle with for sure)
    So three of us trekked down to this event, what a cool thing to use Friday for
    (The photo is taking ages to sync - it will get there eventually)
    I have to say, this is one of the shortest, tightest and busiest tracks I've ever been on
    After a little tuition I settled into a nice rhythm
    My new brake kit struggled a little in the morning as the pads have not been broken in (in anger)
    By the afternoon they were lasting longer and performing very well
    There was a very fast (modified) Mazda 3 MPS doing 42.4 second laps
    There was a tricked out Subaru STI doing 45~46 second laps - going pretty hard
    I was clocked at 48.5 seconds so I certainly didn't let the team down
    My max speed was 118.5km/h (which is a lot on such a little track)
    Most of the time my max boost was ~20psi (but there were a few 26psi spikes)
    While the Toyo R888 semi slicks are not a really great tyre, having so much more rubber on the road was very helpful
    I could get on the power pretty early (Tigger could not, the instructor lit up his inside front Conti, huge smoke)
    I was a little concerned running semi slicks at the front and road tyres at the rear
    Several times the front did bite and tuck in too hard for the rear but it was easy to manage thanks to the inherent good handling of the Octavia
    Here is the obligatory YouTube video of a few laps
    (When I pull off the track you can hear the diverter valve go off)
    MartinOctaviaMarulanMarch2013 - YouTube
    The volume is not very loud because the GoPro camera is inside it's protective case
    If you turn the volume up you can hear a beep or whistle when I'm on power/boost
    Apparently that is very loud outside the car and entertained the spectators
    I was dubbed the "Whistling Skoda", we later decided to call my car the "Scud Missile"
    I took Tigger for a few laps so he can compare his car versus what mine is doing
    Fuel consumption for the day was 16.5 litres per 100km
    That includes the 2 hour drive down there - so the track time was even worse
    Hell of a lot of fun, I'm knackered, off to bed!
    The 'Scud' definitely looks like it moves quicker than stock these days.. nice clip and seems like a good circuit and day (I'd heard the name but never seen it before).
    Bowral, NSW
    The two decent pics of the group!
    Video of the Scud! Screaming Skoda!! - YouTube
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
    Nov 2010
    NSW
    awesome stuff guys!
    martin, loving them rs4-style wheels!
    2012 Yeti 77TSI, Candy White
    ydad.com.au: musings of a dad growing up - the blog.
    cbay.com.au: photography, video, design - creations.
    Dec 2012
    Quote Originally Posted by Mysticality View Post
    Man, you can hear the whistle right from the hairpin, awesome
    (One day we will have to work out what it is - that came with the StageII tune)
    Quote Originally Posted by cbay View Post
    Yeah mate, I have really warmed to them now and prefer them over the Golf R replias
    They not only look good, they have heaps of room for big brakes
    Dec 2012
    Removing the semi slicks gave me a shock this morning
    This is what they looked like before the track day:
    This is what they looked like after the track day!
    They've taked an absolute hiding on the outside edge
    Reminds me of all those years ago playing with Fiat's, Alfa's and Lancia's at track days
    The dreaded FWD Macpherson strut system burring the outside edge of the tyre, grrr
    Dec 2012
    Another thing I learned at the Marulan track day was brake pedal kick back due to ABS operating
    It happened a lot and can be a bit confusing as to what is happening
    Gosford Central Coast NSW
    camber plates!
    Good stuff guys, nice to see some skodas out there on the track.
    '98 Mk3 Cabriolet 2.0 8V
    '99 A4 Quattro 1.8T
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by Martin View Post
    Yeah, par for the course with a stock front end - even with most camber plates, you won't get enough negative camber to prevent the shoulders being chewed out.
    Fiat's, Alfa's and Lancia's eh The older ones with double wishbone front ends were much better in this regard (though to balance things out, you had to put up with the live rear axle or de Dion if you had a posh Alfa )
    This would tend to indicate that your front brakes are way over spec'd, especially given that you were running semi-slicks.
    Resident grumpy old fart
    Dec 2012
    Quote Originally Posted by kaanage View Post
    Yeah - the Fiat X1/9 was the only one that didn't chew the tyres out like this
    But given how low that car is (mid engine also) it's a very different package
    I do think I have more braking power than needed - hur hur hur - LOL
    There was one corner that had a rough entry, that was the one where I was consistently having problems with ABS
    I didn't find a clean line into that corner, inside tyre thumped through the rough stuff and ABS dealt with it, outside tyre was fine
