Results 11 to 20 of 22
Thread: Octavia MK3 oil top up, which brand?
    Pacific Paradise QLD
    Quote Originally Posted by 99Reza View Post
    As long as you stick with VW504/507 approved oil, it should be ok. I believe Castrol is the factory fill. My car seems to be needing a top up every 7000km or so, I used Shell Helix Ultra 5W-30 as it's readily available in the servo.
    Shell Helix Ultra EXTRA is the 504/507 VW approved oil suitable for both petrol and is the grade that must be used in diesels and is not normally at servos or even Supercheap etc Helix Ultra is a 502/505 grade for petrol engines
    Apr 2012
    Upper North Shore,NSW
    Have you checked your tyre pressures since purchase?
    500ml from the bottom mark to the top mark sounds about right. Maybe a fraction more but I've never paid much notice.
    Ya, I check every 3-4 weeks, amazed me when I see one of those guys who pump their tires from 12 PSI all the way to 36 PSI(and I had to wait for 10+ mins for him to pump the tires up), I guess I am like one of those guys to you people's eyes, except it is for the engine oil in my case.
    So, I planned to visit the dealer, but Sydney north's traffic on a Friday avo is unbelievable ,so I ended up buying a 5L bottle of Castrol Edge 5W-30 VW 504 from Repco, they only have couple brands with that spec, so I picked the Castrol as it was the oil in the car.
    Open the bonnet and check dipstick ,it was down to about 3mm below the minimum mark on the dipstick,Topped up the car to about 65% of min to max, didn't want to overfill. and it was fine, the warning sign gone.
    Thank you Guys.
    Feb 2015
    I checked regularly and even noted consumption in my service book. It used about half a litre during the break-in period. I reached the bottom line at about 7000kms, put a litre of the Penrite stuff in (to the top line) and it doesn't seem to have used any significant amount since. We're now at 14,000.
    Sep 2010
    QLD
    Yup that's the one, checked the bottle, Extra ECT or something. Quite expensive too, 20 bucks for the 1L top up. My local Shell seems to carry them all the time.
    I usually almost have to use the whole 1L bottle whenever the dipstick indicator is at the minimum level.
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
    Just check on the label that is says APPROVED for use with VW and the rating as some are rated 502/505 which is NOT for diesels.
    I cant find an extra ECT in the list of approved oils in either rating.
    Very few places carry the 504/507 and usual best avialable is the Penrite Enviro+ 5w 30 at Autobarn or Supercheap
    Erskineville, NSW
    Ultra Extra isn't sold anymore.
    It's Helix Ultra ECT 5w-30.
    The labelling is really crap so you have to be observant.
    Ultra ECT 5w-30
    Octavia MK3 oil top up, which brand?-1l_helix_ultra_ect_5w_30-png
    Ultra 5w-40
    Octavia MK3 oil top up, which brand?-300012225-jpg
    Time to get an updated list of approved oils I guess as the one I have is a few years old now.
    Anyone know of a new one
    Melbourne, Vic
    Nah, just use Australian made, VW approved and certified Penrite, keep a 1L in the boot, and take 5L with you for you service. Just get the correct one for your petrol or diesel engine.
    buy from supercheap or autobarn.
    If you need emergency fill up you need to check that teh oil you are putting in is VW approved. But you should have 1 L of penrite in the boot.
    2001 - A4 B6 1.8T Sedan Manual - (sold @ 254,000km)
    2008 - A3 8P 1.9tdi Sportback Manual - (sold 90,000kms)
    2013 - Octavia RS wagon - 1z - Race Blue - TDI - 6M - Leather - MDI - Whispbar S44W - LED interior kit - RVC forward?/retrofit - Mk3 gear shifter
    2021 - Q3 S-Line wagon - F3 - Daytona Grey - Westfalia towbar - no other options available.
    Jan 2010
    Thread dig from hell
    I'm confused. The Owners Manual has two separate tables that specify oil specs for the 2.0 162, 169kw TSI engine.. One for "Vehicles with variable service intervals" for which they specify VW504.00, and a second table for "vehicles with fixed service intervals" for which they specify VW502.00.
    No viscosity mentioned either, so I'm assuming the certification for each spec relies on a certain viscosity. IE all VW504.00 spec oil seems to be 5W-30.
    Buy some Penrite Enviro+ 5w-30 from Autobarn or similar Probably cheap this week as they have an Easter sale on.
    Dont worry about all the crap in the book
    ALL AUS VW are service at 15000km or 12 months whichever comes first. You can use 502spec but 504/507 is good for both diesel and petrol and it doesnt hurt to use a higher spec oil in any way.
    I use it in the Polo and prev Passat TDI as is easier just to use one.
    CASTROL EDGE TITANIUM SYN 5W30 DPF 5L ENGINE OIL
    Penrite Enviro+ Engine Oil - 5W-30 5 Litre | Supercheap Auto
    Castrol Edge Diesel DPF Engine Oil - 5W-30 LL 5 Litre | Supercheap Auto
