Originally Posted by
dinot81
High quality oils like Castrol EDGE the VW and possibly Skoda uses will hold up to 202 degrees (according to the spec sheet) which is maximum temperature before it loses its last ability as a lubricant.
Castrol Edge has a flash point of 211 deg - you don't want to be anywhere near 200 degrees
http://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/31DA5E6516A53B5980257DFE001321F3/$File/BPXE-9UG2EM.pdf
dinot81
We do legally 110kph here in Oz but imagine drivers in Germany for example using the Octavia 162TSI which has a top speed of 245 to 250kph, the oil would be at 150 to 160 degrees esily.
Oil temperature is not necessarily directly related to speed - it's more about workload
On the track I was hitting 180kmph, the oil only just reached 120 degrees every lap and cooled down quickly when off the throttle
