Thanks, Benji.
I actually posted method on DW and pics, lots of great info. If you spent 40k+ on your car you might as well spend some time and money protecting it. Check the link.
Skoda Octavia VRS meets Prima - Detailing World
2: I didn't cut with compound polish as I had only very minor light swirls that were very hard to see under normal light, I'm happy with 90% correction.
Amigo will fill and has minor abrasives which will to some extent and depending on pad choice do some very minor cutting/jewelling. On VAG paint, I would use firmer pad as it's usually rock hard. Amigo is excellent choice for black paint and the glossy exterior window trim.
I then sealed using machine with Epic which is polymer sealant and then bugged using Hydro Max which is a sealant in its own right but helps to set the polymers and makes removal easy and extends durability. I'm hoping to get 6 months, pure Carnauba waxes don't stand up to ambient heat in Perth especially on our bonnets are metal no insulation to speak of.
There's also nano coatings which can give you 6-18+ months but should be done by someone with some knowledge, experience or at least research beforehand. Whatever you use, you need a clean bare surface so claying is very important.
Let me know if this helps, check the link it has what I used. After this it's only mild wash every few weeks till Sept especially since I top up protection using Hydro Max every month or so.
