Page 99 of 128 FirstFirst ... 4989979899100101109 ... LastLast
Results 981 to 990 of 1279
Thread: OCTAVIA III Owners discussion thread
  1. #981
    Jan 2014
    Narangba, QLD
    I searched the PDF owners manual and there was nothing about using the clutch while stopped at traffic lights, however I did find this regarding the stop start:
    For the system-dependent automatic engine shut-down when stopping or at a
    standstill to operate, the following conditions must be met.
    For vehicles with manual transmission, the shift lever is in the neutral position
    and the clutch pedal is not depressed.
    Cheers,
    Karl
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
  2. #982
    Mar 2014
    Melbourne, Victoria
    Yes, that is exactly how it works with a manual transmission. I do that everyday I drive. Nobody taught me, but I've always put the car in neutral at lights, releasing the clutch and held my foot on the break.
    Quote Originally Posted by Jondalar View Post
    Walking Contradiction...
    MY15 Skoda Octavia vRS 162 Race Blue Combi
  3. #983
    Erskineville, NSW
    Back when I drove manuals I was taught to put it in neutral, too much wear on the throw out bearing if you're sitting with the clutch in for minutes.
    That's probably more applicable to cars pre-1970. IIRC some of them used to have "self lubricating" carbon or copper/bronze bearings that would kack themselves if they had too much pressure on them for too long. I haven't seen that setup for a long time. I think the English engineers were fond of it?
    I mainly go nuetral / clutch out to stop my leg getting cramped.
    I think a lot of the old rules have gone out the window. You were always taught not to coast in nuetral - now the cars do it automatically.
    Old cars had tiny exhaust pipes because engines needed back pressure - I still have no idea what that was all about.
    Oil changes every 1,500km (I had customers that came in every 2 weeks) - now it's 10,000km+
  4. #984
    Bowral, NSW
    Yes, this. Me too - even in my tiny Up! (with the lightest clutch I've ever driven) Also helps the process feel more formal, so you can choose when and where the engine will switch off; I guess it gives you even more "manual" control over the vehicle.
    The "pumps" (because its not a smooth flow, its on/off/on/off) of exhaust gas maintaining a certain velocity and "sucking" exhaust out of a cylinder when the valve opens to help clean it out to empty it and get it ready for even more clean air.
    Rendered null and void as soon as you add a turbocharger.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  5. #985
    Yeah the coasting I was told, and not to sit riding the clutch at lights etc. With hill start there isn't much need for that now. I hired a RS Megane over the weekend just before our Skoda was delivered and those have a really heavy clutch, I did the above many times as it killed my achilles. Could be where this also come from before when clutches were pretty heavy things to deal with. I remember learning how to do steep hill starts in my Dads early 90s Patrol which had effectively small truck gearboxes in them. If you can do that without stalling or rolling back you can drive anything! Ditto for parallel parking in them. I only did a few driving school lessons before my test only to really find any tips or tricks they knew about the testers, and the only thing I picked up there was not wrapping your thumbs in the steering wheel so they don't get broken.
  6. #986
    Jan 2014
    Narangba, QLD
    Anyone with a diesel Octavia tried one of these? OBD2 Power Box Skoda Octavia III 2.0 TDI 150HP Diesel Chip Performace ver.2 | eBay IF it worked it would be a very subtle and easy way to get a bit more power.
    Cheers,
    Karl
  7. #987
    Nov 2009
    Illawarra NSW
    Cheers,
    Karl
    Are you serious ? The only thing it will do is lighten your wallet !
    2014 MY14 Corrida Red Elegance Wagon TDI
    2009 MY10 Race Blue RS Wagon TSI 6 sp. manual. (Gone)
    2011 MY12 Yeti 77 TSI DSG.
  8. #988
    Bowral, NSW
    Plug and play boxes; no matter how fancy; are far more dangerous than a real ECU tune. Please be careful.
  9. #989
    Newcastle, NSW
    Haven't read the manual, so may be covered, but my stop start kicks in but it starts back up again 25 seconds or so later without me releasing the brakes etc. Is this normal?
    MY16 RS wagon. DSG.
    Audi S3. Sold
    Golf R. Sold
    Citroen DS3 Dsport. Sold
    2016 Skoda Octavia RS Wagon.
  10. #990
    Bowral, NSW
    Quote Originally Posted by Ideo View Post
    It starts the engine if it needs it for whatever reason; including:
    Charging the battery
    Running the A/C
    Rebuilding vacuum pressure
    How hot is it outside, and how cold is your a/c set to?
