Page 33 of 128 FirstFirst ... 2331323334354383 ... LastLast
Results 321 to 330 of 1279
Thread: OCTAVIA III Owners discussion thread
  1. #321
    Oct 2014
    Ballarat, Victoria
    What is everyone using for a sun shield for the front windscreen? I found some generic "fits all" screens but is there anything special I should be looking at?
    MY15 RS Wagon, Black Magic, Manual, Leather, Tech Pack, 18" BP
  2. #322
    Apr 2008
    Western Sydney
    Just have those collapsible generic ones from Autobarn
  3. #323
    Erskineville, NSW
    Quote Originally Posted by Dzl_Dubba View Post
    Yep have been checking them out too. The bbs go for about 800-900 each, hence the if i had the money comment haha.
    Edit: These have my attention
    The White + black + gold (matt bronze or whatever it is) looks way too busy.
  4. #324
    Sep 2014
    Canberra
    Anyone notice issues on idle?
    When cold (After sitting over night) it runs a bit rough, once I thought it was going to stall but it recovered itself.
    If I give it some revs its happy but when they drop back down it splutters a few times before leveling out.
    It gets better after it is warm but I can still feel it when sitting at lights. Not as bad just small jutters.
    I have <1000KMs on it so I was wondering if the engine is just working its way in but I mean, it just seems strange its like the injectors are not giving it enough fuel.
    I am going to bring it up with the dealer but thought I would check if anyone else is having issues.
    Unrelated - Front speakers in the tops of the doors and center of the dash (canton unit) Anyone having issues with buzzing type vibrations, specifically on voice when they are talking on the radio.
    Candy White RS Wagon 162 TSI Manwell. 18" Black Pack, Sunroof, Tech Pack.
    Ordered: 22/09/14 -
    Built: 14/11/14 - ETA: 31/01/15 - Delivered 03/02/15
  5. #325
    Erskineville, NSW
    Quote Originally Posted by Opie View Post
    Engine still tight & ECU still learning (it actually adjusts the individual firing of each cylinder to improve idle). 1000km isn't even 2 tanks of fuel. It takes about 5000km to get the initial run-in and 10,000-15,000km afterwards will give gradual improvements.
    Suggest you get out there and make several brisk ascents up Black Mountain. It will help.
  6. #326
    Sep 2010
    QLD
    Opie:
    I have exactly the same issue. I posted on the exhaust thread Exhaust Thread page 5
    I have done almost 15000 km on the car, still the same thing, no changes on the idle and jutters whilst sitting in the traffic. Does yours get better after switching on the A/c? Mine does.
    I had a misfire once on cylinder 3 whilst driving on the highway, fixed itself right away, not sure if it's related or not.
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
  7. #327
    It believe it has to do with emissions / cold start. Lots of (European) cars do this and I am lead to believe it is normal/acceptable. My old Clio Sport RS172 used to do this and as do current RS Meganes so I wouldn't worry about it.
    Re: buzzing .. this is a technical fix which has worked for me .. bang it with your palm until buzzing disappears .. if that doesn't work, try some silicone spray (WD-40 brand from bunnings).
    RS
    R
  8. #328
    Glen Waverley, VIC
    +1
    Mine: Octavia vRS Combi (MY15) | Brilliant Silver | 6MT | 162Kw 350Nm | Tech Pack* | 18" Black Pack | Leather | Sky Port | Ordered Aug 14 | Built Wk 48 2014 | Landed 3/2/2015 | Delivered 20/2/2015
    Hers: MY06 MkV Golf TDI 6DSG | Silver | Stock | RNS510 + Badge RVC Installed.
    Weekender/Project:
    Classic Mini 1972
    Dependant #2: Mk4 2001 GTi
  9. #329
    Jul 2014
    FYI - For anyone needing to replace any rear light bulbs please note that the torx screwdriver supplied may not fit the torx screws that hold the tail lamp assembly in (page 261 for the Estate in the owners manual). The two ended screwdriver supplied in the spare wheel well is just slightly too big to fit into the screws. After much swearing and trying to resort to a flat head screwdriver I gave up...
    Ended up buying an assortment of torx screwdrivers from Bunnings today and confirmed that a T15 torx head is needed for this.
    2014 Skoda Octavia RS Wagon 162TSI DSG, candy white.
  10. #330
    Oct 2010
    While I agree a solid run in will help for sure, I think this is a legitimate issue. Gerrycan also noted this issue on his car.
    My car (with only ~2400k's) is smooth as silk on cold start. No coughs, lumps or shuddering. Although cold start in qld summer is >20 deg C. The engine is so smooth/quiet, its hard to tell its running most of the time, especially at cruise or idle.
    2014 Skoda Ambition Plus 103TSI candy white wagon, 6sp Manual, Tech pack, Panoramic Sunroof, 18's, Colour Maxidot, Comfort BT
    Ordered 07 May 14 (Wk 15), Built Wk 37, Loaded 27/9 (wk 39), Docked 12/11 (wk 46), DELIVERED! 12/12 (end of wk 50 - 7 months + 1 week).
