Page 124 of 128 FirstFirst ... 2474114122123124125126 ... LastLast
Results 1,231 to 1,240 of 1279
Thread: OCTAVIA III Owners discussion thread
  1. #1231
    Sep 2016
    Hmm.... something for us all to keep an eye on I guess, while our cars are in warranty.
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
  2. #1232
    Sep 2010
    QLD
    Apparently wheel bearing issue is quite common for our car. I had one of my wheel bearing replaced very early, around 25000 KM, although a largish rock on the freeway might caused the failure . The dealer didn't even bat an eyelid.
    Come to think of it, my C-class hit a very large pothole on the way to Sydney from Brisbane and shred one the tire, no issue on the wheel bearing. I suspect Skoda used a lower quality bearing.
    2011 Tiguan 125TSI - SOLD
    2014 Race Blue Octavia RS 162TSI Combi
    Check out my leather work ----> http://pedsnro.blogspot.com/
  3. #1233
    Jun 2016
    Quote Originally Posted by 99Reza View Post
    Nice
    Between track days and a dodgy driveway, I do feel for them, so thats nice of skoda.....
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  4. #1234
    Jan 2014
    Narangba, QLD
    Wouldn't start
    Just got back from a 4 week overseas trip, Octavia was left locked in garage the whole time. When I got back it unlocked OK and I tried to start it. Pushed the stop start with foot on brake and nothing happens. Tried again several times and still nothing, check engine warning light stays on but no other indication. Decided battery must have died (cranked slowly during winter a few times) and called Global Assist. Well he checked the battery and said it tested as perfect. He got the key and tried to start, starts first go. Moral of the story: if the car hasn't been run in a while there will be no vacuum brake boost and you have to push really hard on the brake pedal for the car to recognise that it's pressed....
    MY18 Passat Alltrack Wolfsberg (white) darkest legal tint (SOLD), 2014 Golf 110 TDI Highline (sold after DM Flywheel issues), now 2021 RAV4 Cruiser Hybrid, 2020 C-HR Koba Hybrid
  5. #1235
    Good to know, I'll be away a similar time next year and will have the other car on charge, but can't do both.
  6. #1236
    Sep 2016
    Quote Originally Posted by Jondalar View Post
    .......if the car hasn't been run in a while there will be no vacuum brake boost and you have to push really hard on the brake pedal for the car to recognise that it's pressed....
    No offence, but is this the explanation the mechanic dude gave?
    The switch that operates the brake lights, on the pedal, is what signals the car that the brake is pressed, in order to start the car... or at least, it is in every other car with the safety feature of "foot on brake before you can start"..... I doubt it has anything to do with vacuum booster pressure.....
  7. #1237
    Jan 2014
    Narangba, QLD
    Quote Originally Posted by Spinifex View Post
    Yes that is what the mechanic said was the cause. I did notice that the brake pedal was rock hard when trying to start it but I thought like you it was just a switch.
  8. #1238
    Jan 2014
    Narangba, QLD
    I tested the brake interlock this morning, pumped the pedal with engine off until the pedal was hard and then tried to start while pressing pedal with the normal pressure, nothing. Stomped on it and car started. I guess it might be the same pressure sensor used for the stop start i.e. when braking lightly enough the stop start won't stop the engine but press harder and it does.
  9. #1239
    Bowral, NSW
    We don't have a brake light switch like Japanese cars; its all done by brake pressure. You need to push it down a little further when there's no vacuum so that the sensors can detect movement of a considerable amount.
    2012 Octavia vRS TDI. Darkside big turbo, 3bar tune, other stuff. 200kW/650Nm.
    1990 Mk1 Cabrio. 1.9 IDI w/ 18PSI.
    1985 Mazda T3500 adventuremobile. 1973 Superbug. 1972 Volvo 144 in poo-brown.
    Not including hers...
  10. #1240
    Sep 2016
    Quote Originally Posted by Mysticality View Post
    Well there ya go.... learn something new every day. That's a bit of a roundabout method to achieve something that a simple electrical switch has been used for, for many many years.....
    Why re-invent the wheel? Is there a specific engineering reason for this method of "signal activation?"
